What is the best kind of license plate mount
Kuryakyn makes a nice one, well made with an LED run/brake. It mounts to the swingarm. I don't think a beltguard would be stable enough. You route the wiring back up to the battery box and pick upthe harness going to the taillight and use the quick connect splicers to tie in.
see it here.......I set mine up with the light at the top.....in this picture it's on the bottom.
http://www.motosport.com/harley/sear...20curved&src=s
Greetings,
I'm running a V-Twin Motorcycle Parts belt guard side mount kit for a '06-'07 FXST. I have white LED license plate light bolts that work just fine on there. As far as the wiring goes, I encased the two wires in black shrink-wrap and ran it along the swingarm. You can't tell at all they are there (It helps that my frame is black).
You'd have to whack it pretty hard to break it, like lay the bike down. I don't imagine the one I have would break easier than any others I've seen. It's very stout, and heavy....great chrome too. They may make a cheaper version but the one I posted the link to is solid.
I installed mine on the shock bolt but could put it on the belt guard or axle. Ordered the side plate off ebay for $22.00 and some Black LED tag bolts $16.00 (links below).
here are pics:
http://www.harleyalley.com/showphoto.php/photo/542
http://www.harleyalley.com/showphoto.php/photo/557
Black LED Tag Boltz
http://www.customdynamics.com/illumi...%20Tag%20Bolts
Side plate
http://stores.ebay.com/Road-6-Custom...QQftidZ2QQtZkm
here are pics:
Black LED Tag Boltz
Side plate
here are pics:
Black LED Tag Boltz
Side plate
here are pics:
Black LED Tag Boltz
Side plate
do you have a pic with your mounted. I just purchased one with the brake light. I have mine rough mounted with it on bottom. I kinda like it that way but was wondering about on top.
jim
Having done about a dozen different side mounts over the years I have to save the best damn built ones are from Heartland USA. They mount to the inside portion of the rear footpeg mounting hole. They are built like a brick ****house and they fold in, and the finish is very durable so if you lay the bike down there is a good chance you wont destroy it. Comes in 3 flavors, chrome, black, or black and chrome. DOT approved as well.
