Widest rear tire on stock FLSTC rim?
Old 12-13-2008, 06:03 PM
albngore's Avatar
albngore
albngore is offline
Default Widest rear tire on stock FLSTC rim?
Without any kind of mechanical alterations, what is the widest rear tire that I can replace my OEM Dunlop with please? If it is not possible with the same rim, then what is the widest rim/tire combo without mechanical alteration? Thanks.
Old 12-14-2008, 12:24 AM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is offline
Received 3,798 Likes on 1,675 Posts
With your stock 3" wheel, a 150 is the widest tire that will fit. A 160 is probably the widest tire you will be able to fit without any mods other than having to go to a 3.5" wheel. I use a 150 V rated Avon on mine as it is a smidge wider than an H rated Avon. About 4 mm wider. BTW, with that slightly wider Avon, there is ery little room between the tire and the fender.
Old 12-14-2008, 07:17 AM
tk353's Avatar
tk353
tk353 is offline
I have a metzler chart i can email you if you pm me with your email address
Old 12-14-2008, 07:38 AM
BK Meyers's Avatar
BK Meyers
BK Meyers is offline
Default same question but different year??
I have the very same question but my bike is a 1997 model FLSTC. Though the original post does not specify I'm assuming his bike is a 2000+ model. Will the 150mm tire also work on the 1997 model without modifications??
Thanks,
BK
Old 05-18-2023, 02:47 PM
ghostrider_33's Avatar
ghostrider_33
ghostrider_33 is offline
Stage I
Default Wheel/tire sizes
here is a cheat sheet link
https://ridewrightwheels.com/pages/motorcycle-wheel-fitment-chart
Old 05-18-2023, 06:54 PM
stanleytax2023's Avatar
stanleytax2023
stanleytax2023 is offline
Stage II
Thanks for the info ghostrider
jada3058
07-07-2011 11:16 AM
mud runner
04-15-2010 02:44 AM
skintbackfarms
04-26-2009 08:44 AM
docsg
11-19-2008 10:54 AM
zio
08-03-2008 08:27 PM
Quick Reply: Widest rear tire on stock FLSTC rim?
