My 2007 Fatboy still has the stock exhaust system. I need to adjust the final belt drive. Obviously, there is no problem in accessing the adjustment bolts on the drive side, but what the heck do you do to access the adjustment bolts on the exhaust side?? There is just no way to get any wrench or tool to get past the exhaust silencers in order to grab the head of the adjustment bolt.
Please don't tell me I have to remove the exhaust to adjust the belt...
Thanks for any advice.
Alan
You can get in there with a crow's foot, but the easiest way is to take the muffler off. The muffler clamp is a one use "Torca" clamp. You can try to reuse it, if it doesn't hold tight, you may have to get a new one, about $8.
When I had the stock pipes,I had to remove the slip-on to get to it...I know just get new pipes while your at it,that way next time,your all set
That would be nice... That is, to get new pipes.
Originally Posted by anubisss
Good excuse to get new pipes if you ask me. "Honey, I couldn't get to the bolt without changing the pipes."
Maybe we can form a support group that will rally around my cause and we can all sing in unison... "He needs new pipes...He needs new pipes"
Truth be told, I actually like the stock pipes and how they fit the bike, at least as far as looks are concerned. It just sucks to think you gotta take apart the exhaust to get at that bolt!!
Thanks for the tip on the Torca clamp. I'm generally fairly careful when I dismantle stuff, but sometimes things just happen. I will likely pick up couple of those clamps to have in the spare bin. But, I like the idea of crow's foot..., that might just do the trick.
Thanks!!
Hey crazybastid83,
I used a crow's foot. And, guess what, it worked. I borrowed a 9/16" crow's foot and slip onto the end of a 10" drive extension. It was tricky at first, but once I realized I was able to get full range of movement as I rotated the extension with a ratchet, there was no problem. To tighten it up, I was still able to "insert" an open 9/16" box wrench in between both mufflers and hold onto the adjustment bolt while I tightened the set knut with the crow's foot. Waa Laa. The belt was adjusted all in about 7 minutes. Obvioulsy, were it not for the stock mufflers as they are placed directly off the axle and belt adjustment bolt, it likely would have been easier. But, using your suggestion, I did not have to mess with the stock exhaust at all. Thank you!!!!!!!!!!!!!!!
Ride safe!
