rear belt replacement
Old May 26, 2009 | 09:30 AM
waynemags's Avatar
waynemags
Default rear belt replacement
doe you need a special tool to put a rear belt on a flhtc evo style bike? is there a tool to line up the swingarm or can yo just take pivot bolt out and reassemble as is and keep everything straight. i definately cant afford the dealer to do this job at there rates of 96 bucks an hour. any input would be great. thanx
Old May 26, 2009 | 09:36 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Just take off the swingarm, put the new belt on and bolt the swingarm back on. A fair amount of work but nothing too difficult.
Old May 26, 2009 | 10:00 AM
waynemags's Avatar
waynemags
are you talking the arm that the shock attaches to on the belt side or do i have to pull the pivot bolt. im waiting for my manual to show up. im guessing by looking at it that i can probably remove just the one side and slip the belt in.
Old May 26, 2009 | 10:17 AM
EasternSP's Avatar
EasternSP
If you look at your drive belt then visualize how you would remove it from the bike, you will see that you have to take the swingarm off in order to remove the belt. Just a lot of work, but like you said, it would be expensive for the dealer to do. Nothing real complicated about it nor does it require special tools except for the belt tension measuring tool. That's about $10 bucks and you can use it over and over.
The work will get you more familiar with your bike.
While you have your swingarm off, you might consider installing the nylon stablizer bushings.
Old May 27, 2009 | 06:06 AM
t150vej's Avatar
t150vej
It takes a special puller to R&R the inner primary bearing race that is on the trans mainshaft. They get a wear groove from the inner primary seal and really should (most often) be replaced whenever the inner primary seal is disturbed.
Beyond that, the only special tool needed in the entire procedure is what the book shows as a home-made alignment tool. Basically, a long L shaped rod that will help you measure from the centerpoint of the pivot bolt for the swingarm to the centerpoint of the axle. Axle alignment is extremely important on them for proper handling and tire wear.
If the belt is not cut on the side or punctured from road debris, they are almost indestructable. The teeth on them will look chewed up from wear, but that doesnt hurt anything. Replaced mine at 82,000 and it looked rough, but was a waste of money in my opinion.
Old May 27, 2009 | 06:22 AM
Notgrownup's Avatar
Notgrownup
I was gonna ask....why are you changing it....These belts last and last....ride it until it starts to show cracks or frays....waste of time to change too early...
Old May 27, 2009 | 06:30 AM
t150vej's Avatar
t150vej
PS
You do not have to "remove" the swingarm. Take the left rear shock loose at the bottom (or off) Remove the pivot bolt, drop the front of the arm down and you'll have plenty of room to slip the belt past everything. But remember, the entire primary must be removed. Outer and inner covers, including compensator/primary chain/clutch assembly and part, or all of your starter, depending on the year...
Wait on your book before getting too gung-ho about the deal
Iarecobra
May 7, 2017 01:09 AM
37sportster
Mar 26, 2011 08:49 AM
RockDog
Jun 6, 2010 01:49 PM
00glider
11
Sep 26, 2007 03:42 PM
barkster99
Jul 26, 2007 02:37 PM
