Anyone installed a rear turn signal relocation kit lately?
Old 04-12-2009, 05:17 PM
dugan's Avatar
dugan
dugan is offline
Default Anyone installed a rear turn signal relocation kit lately?
Have to replace a rear turn signal. It appears the two wires run from the turn signal to the brake light. Where do I remove the wiring from in order to rethread it thru the turn signal relocation shaft? Inside the bullet turn signal or the brake light? Will I have to splice? This seems like a simple job that I don't want my dealer charging me a buttload to do.
Old 04-12-2009, 06:07 PM
gwalsh's Avatar
gwalsh
gwalsh is offline
I installed the kit a couple weeks ago and the wires were cut and spliced with supplied butt connectors. I also had to lengthen the wires.
Old 04-12-2009, 06:10 PM
Loud1's Avatar
Loud1
Loud1 is offline
When I did mine I cut the wires under the fender and used the connecters like gwalsh
Old 04-12-2009, 06:17 PM
anubisss's Avatar
anubisss
anubisss is offline
I unplugged the signals from inside the taillight and took apart the connector and reran the wires and put it back together. Pretty simple. Jsut use a pick or small eyeglass screwdriver to disassemble.
Old 04-12-2009, 06:44 PM
08Fatty's Avatar
08Fatty
08Fatty is offline
Mine came with extensions. I guess its a new feature.
Old 04-12-2009, 08:37 PM
nhbouncer's Avatar
nhbouncer
nhbouncer is offline
+1 on that surely the best way to do it, will only take a few extra minutes compared to having a splice under the fender.
Old 04-13-2009, 07:55 AM
tk353's Avatar
tk353
tk353 is offline
Old 04-13-2009, 08:01 AM
jknowlton's Avatar
jknowlton
jknowlton is offline
wow really. Took HD forever to think of that. Thought that was just ridiculous that they did not have that included or some simple plug in ones.
Old 04-13-2009, 08:31 AM
Bryanp's Avatar
Bryanp
Bryanp is offline
I just did mine yesterday. Mine did not come with extensions and i didn't figure out that i needed them till after i got everything together and tried to plug the turn signals back in. needless to say that i took it back apart and had to add about an 1" of wire just so i could plug everything up. Oh and lets not for get that one of the turn signal stems needed to be drilled or "massaged" to be able to get both wires threaded through it. It was a blast. have fun
Old 04-13-2009, 10:37 AM
jknowlton's Avatar
jknowlton
yes. this was absolutely the worse part. I had to have a friend (female) do it, because my buddy and I did it both on to our bikes, and just did not have the patience and crazinees. I can't believe they cant make it easier with extensions or something.
Quick Reply: Anyone installed a rear turn signal relocation kit lately?
