Charging system amperage?
Anyone know what the stock charging system output on a 2005 Night Train is? I'm looking to run two sets of heated gear for a road trip this winter. The total draw for the gear will be 28-29 amps.
I'm thinking it's either 32 or 38 amps, but I can't seem to find it anywhere.
I've seen 45 amp stators for the touring bikes, but does anyone know of an upgraded charging system for the "B" motors?
Edited to add- It looks like it's 38 amps stock, I guess the question then is will the bike run on 9 or 10 amps, or is that going to discharge the battery and kill the bike?
I dunno. Next step is to call Gerbings and see what they say.
I did mix a tourmaster jacket + chaps with Gerbing Gloves, here is a suggestion for you (would not be very expensive)..
INstead of using the socks, just use 'Toe Warmers' .. they are cheap disposable and for 2$ you get 5 hours , if you did ride 50 hours in your trip you are looking at 20$.
And you save 5 amps right there.
Good luck but I must agree heated gear is a must in this cold weather coming ahead of us as long as there is no white stuff on the ground.
