Engine stall
Old 01-05-2010, 12:02 PM
munozda's Avatar
munozda
munozda is offline
Stage II
Angry Engine stall
I have a 2002 FLSTF Fatboy that keeps stalling on me. The bike runs well for awhile then stalls. The bike will crank but will not turnover until it has been sitting for awhile ( usually the next day ), then it starts right up. Start up, ride, stall, wait a few hours, start up again-repeat! Any advice would be appreciated.
Old 01-05-2010, 12:10 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,935 Likes on 1,919 Posts
Clean the IAC on your throttle body. Hit it with some fuel injection or carb cleaner. Also clean your CPS down near the oil filter.
__________________
Old 01-05-2010, 01:37 PM
Chazmanian's Avatar
Chazmanian
Chazmanian is offline
R.I.P. BROTHER
Is the bike carbed or FI?
Old 01-05-2010, 07:32 PM
snook592's Avatar
snook592
snook592 is offline
What temps are you riding in?
Old 01-06-2010, 08:51 AM
tk353's Avatar
tk353
tk353 is offline
sounds like my old car. bad plug wires or coil. heats up and breaks down. could be crap in the tank, when it cuts off try starting fluid and if it runs it is fuel related
Old 01-06-2010, 11:20 AM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
Had that problem with my cage, turned out to be the CPS. Don't know how it works on a bike but on the cage it shuts down both spark and fuel when it's not working right. And it shuts down instantly as if you turned the key off. No spit and sputtering.
Old 01-06-2010, 01:21 PM
drjones's Avatar
drjones
drjones is offline
Hey Mun, my advice is, plan on taking short rides and long breaks in between, this way your butt wont get sore.. OK, just kidding.
You will have to narrow it down to either electrical or fuel related. When the bike dies, pull a plug wire and check to see if your getting spark. If you are, then it will be fuel related. Next question, is it carb or FI?
Old 01-06-2010, 03:08 PM
Irish Rod's Avatar
Irish Rod
Irish Rod is offline
If it's a carb model it sounds like fuel starvation. Could be a clogged fuel filter in the gas tank or blocked inlet valve in the carb.How far do you get before the problem appears. Having said that ,buddy of mine had the same problem and it turned out to be a faulty ignition coil.
Old 01-06-2010, 03:24 PM
BigJoeNY's Avatar
BigJoeNY
BigJoeNY is offline
They quoted 2002 FLSTF. That's a carb.
Old 01-06-2010, 08:16 PM
poppazoidi's Avatar
poppazoidi
poppazoidi is offline
6th Gear
I had the same problem on my '98 FLSTC. It even stimied a HD tech who spent three and a half hours on it. Cleaned carb, changed coils, cleaned fuel filter, verified vent in gas cap was clear and functional. The bike would shut off with no coughing or sputtering. After sitting from five to fifteen minutes, it would start up and go. I knew it had to be heat related and after talking to an old EVO mech, he said it was the Pulser Module. I had it replaced with no further problems. The modulle is located under the cam cover on the right side near your foot (floorboard).
Quick Reply: Engine stall
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
