'10 Fatboy backrest install question
Old 01-23-2010, 01:31 PM
NOLaFatBoy's Avatar
NOLaFatBoy
NOLaFatBoy is offline
Default '10 Fatboy backrest install question
I picked up a rigid mount sissy bar backrest/rack for my fatty. there is a reflector between the last two strut bolts. Using the existing bolts, do I just install over or do I have to remove the reflector?
If the reflector is removed does having the rigid plate bolted directly against the bike do any damage (scratches) to the strut?
Am I better off just picking up detachable plates and the hardware to mount them?
Old 01-23-2010, 02:30 PM
stro1965's Avatar
stro1965
stro1965 is offline
Without actually seeing your bike to know exactly what you're talking about, I would say the reflector would have to come off. Once the rigid sideplates are bolted down tight they shouldn't cause any damage to the struts.
Old 01-23-2010, 03:30 PM
dugan's Avatar
dugan
dugan is offline
yes, the reflector needs to be removed, it's on there with double sided tape so a little heat on it and it should come right off. The side plates should come with a protective piece of tape to put in between the strut and plate. I started with the rigid mounts and shortly after exchanged for the detachable plates. liked the easy on and easy off of the backrest, most of the time I ride without a backrest, only when she rides do I put it on. so the detachable is more convenient.
Old 01-23-2010, 06:20 PM
NOLaFatBoy's Avatar
NOLaFatBoy
Here is a pic of the struts reflector
If I go with the detachable plates and hardware do the reflectors still need to be removed?
Should I use some clear plastic packing tape as a barrier between the plate and strut?
I'm using this backrest/rack mainly for a place to strap a small bag... for rain coat etc...
Old 01-23-2010, 06:32 PM
dugan's Avatar
dugan
dugan is offline
I think you want those plates as close to the strut as possible, I would imagine they would crack after a few uses of the backrest on anyway. most new bike owners take the reflectors off the forks and struts before they get the first 50 miles on
Old 01-23-2010, 06:38 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,935 Likes on 1,919 Posts
Dump the reflectors. That is how it is done. Fishing line and goo gone.
__________________
Windseeker
05-08-2019 08:43 PM
stv1520
06-24-2014 05:16 PM
Arz135
06-24-2014 03:32 PM
swilcoxaz
04-20-2011 08:59 AM
Bradley Jones
03-30-2010 03:09 PM
Quick Reply: '10 Fatboy backrest install question
