Removing Rear Fender Bolts
Old 04-16-2010, 06:19 PM
ia2189's Avatar
ia2189
ia2189 is offline
Question Removing Rear Fender Bolts
I'm trying to install Easy Brackets for some detachable saddlebags but can't get the rear fender bolts off for the life of me. I even kind of stripped one so I'm thinking I'm going to have to go to the local dealer anyway, but does anyone have any tips for getting these off? I bought the bike used last year so I don't know if the previous owner used the wrong Locktite or what.
Old 04-16-2010, 06:20 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
There is a nut on the back side of the bolts. If it is really tight hit it with a bit of heat or put the torx or allen in and whack it with a hammer a few times.
Old 04-16-2010, 06:35 PM
train913's Avatar
train913
train913 is offline
+1 little heat will do the trick
Old 04-16-2010, 06:43 PM
hspring03's Avatar
hspring03
hspring03 is offline
Make sure you have the proper size torx head....... A little heat does help.
On an 06 you might have the nut kit on the inside of the fender and no nuts.
I've stripped them before, cause the locktite can be a bear....If that's the case just drill them out and replace with new bolts from your local hardware store...
Old 04-16-2010, 06:55 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Ace is the place.
Old 04-16-2010, 10:04 PM
travis dasher's Avatar
travis dasher
travis dasher is offline
take a soldering iron to the bolt, this will heat it up and will loosen the locktite. Replace those soft torx head bolts with some deep allen heads, they wont strip. Be sure to use antiseize if they are Stainless
Old 04-17-2010, 12:21 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,220 Likes on 4,770 Posts
Go pick up a hand held impact driver. You can get one at Harbor Freight pretty cheap and it's good to have in your tool box anyway.
Old 04-17-2010, 09:16 AM
tk353's Avatar
tk353
tk353 is offline
i used the torx and vise grip and that got it loose and to the trash. it is the factory glue. i did not have any nut on the back side of the bolts
Old 04-17-2010, 11:55 AM
gforrest2's Avatar
gforrest2
gforrest2 is offline
Mine were a bitch to get off too. Just about stripped one out. It's the factory lock tite. I had to put a pipe wrench on the handle of my torx driver to get more leverage. I'll try the heat next time.
Old 04-17-2010, 02:26 PM
Rockrspud's Avatar
Rockrspud
Rockrspud is offline
Mine had the nut's inside the fender
Quick Reply: Removing Rear Fender Bolts
