Night Train new wheels & tires sizes
Old 06-05-2010, 02:08 PM
6fthook's Avatar
6fthook
6fthook is offline
Default Night Train new wheels & tires sizes
Looking for some help here. Searched the forums and google extensively but don't have my answer yet.
I'm planning on getting new wheels and tires in the near future, both front and back. I want to go from the stock dunlops (200mm rear) to a metzler 210mm, and in the front to a bigger than stock front, probably a 120mm metzler.
From reading people's posts, the best thing to do would be to keep the stock geometry with the tires.
Which metzler front/rear combo would be the best to achieve the best tire geometry? And would a size other than 120 be better (I just want bigger than stock)?
Rear:
200/55/17 (stock) 651.8mm
210/40/18 metz 625.2mm
210/50/17 metz 641.8
The front I'm a little confused on.
Stock is MH90-21 54H. Is the 90 the width of the tire? 21 the rim diameter? But where is the aspect ratio?
For rims, in front I'm planning on getting a 21x3.5 or 21x3. Rear, hdwheels.com has 17" at 6-7" width, and 18" at 7-8" width. What's the difference, if any, with going with the lower end compared with the higher end?
Thanks in advanced for any help you can provide!
Old 06-09-2010, 08:49 AM
6fthook's Avatar
6fthook
6fthook is offline
any ideas?
Rear going to get a 6.5 so I can use either 200 or 210. Is there a front width that I could use either the 90 or 120?
Old 06-09-2010, 03:53 PM
VTwinPulse's Avatar
VTwinPulse
VTwinPulse is offline
I went with a PM 18x5.5 rear and a 200/5018 Metzeler Marathon 880 on the rear and a 21x3.5 front with a 120/70/21 Metzeler Marathon 880 as well.
I would like to put a 210 on the 18in rim down the road but not sure how tight it will be.
Dont know if this helps bro.
Old 06-09-2010, 05:32 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
6ftHook,
I recently faced the same challenge as you are. Didn’t like the narrow front tire on my Train. To keep the 21 inch up front, and increase the tire width to a 120 series, you’ll need a 3 inch wide rim. “Hog Pro” hooked me up with a bolt-on replacement rim which included the correct hub for my bike. I also ordered one of their brake rotors and had them mount and balance a tire prior to shipment.
The wider tire in the front improved stability and handling of the bike and I’m glade I made the switch. Google “Hog Pro” to retrieve the phone number and give Glenn a call.
Attached Thumbnails Night Train new wheels & tires sizes-1.jpg   Night Train new wheels & tires sizes-2.jpg
Old 06-09-2010, 06:41 PM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,055 Likes on 631 Posts
I just went 1 size bigger on my Front MH 90 on bike,, New 90 90 , alittle wider and taller
Old 06-09-2010, 06:47 PM
dennyo's Avatar
dennyo
dennyo is offline
O-Ya just so you know the Fender didn't Fit I just had it layin on there , just got my new Fender from Ebay still gotta mount it
should have it on this weekend and I'll have Pics
Old 06-10-2010, 09:55 PM
brooks79's Avatar
brooks79
brooks79 is offline
Went with the same wheel set up for my 09 nigh train, 18x5.5 rim, tire/200/50/18 rear and 21x3.5rim,tire 120/70/21 front with metz 880, I got them in and went to put them on and the hubs were offset wrong, But From what I can tell it will look alot better. From the guy I purchased the wheels from everthing should be at the same heights.
ballbreaker69
08-28-2017 10:32 AM
midwestRyan
03-31-2015 06:52 AM
stevepacman
01-17-2009 08:31 AM
bonzi88
11-09-2008 03:33 PM
gussie78
04-26-2007 01:27 PM
Quick Reply: Night Train new wheels & tires sizes
