DTC P0131 - possible causes?
Old 07-05-2010, 12:05 AM
tk353's Avatar
tk353
tk353 is offline
19.36 is the reading you get from the heater in the o2 when it warms up. seems you are not getting the data from the o2 sensor. yes sensors can go bad.
Old 07-07-2010, 09:25 PM
tk353's Avatar
tk353
tk353 is offline
i got the email from zippers and they said to check the grounding on the pipes. did you use new gaskets on the pipes? maybe run a ground wire to the header bolt.
Old 07-08-2010, 06:37 AM
SpicOfTheDevil's Avatar
SpicOfTheDevil
SpicOfTheDevil is offline
yes...still need to check for a leak
bellmnbell
12-08-2016 07:18 PM
markdavidson
2014-2023 Touring Models
09-19-2016 04:29 PM
coachchris
06-04-2011 07:15 PM
ricaroo
01-29-2010 10:27 AM
brandanfinn
06-27-2007 09:04 PM
Quick Reply: DTC P0131 - possible causes?
