Cam Bearing disaster averted !
I got lucky.
On my 01 FXST at 58K Km (36K miles) , I decided to rest my mind and replace my my Cam Chain tensioners to the Hydraulic ones, using Andrews Kit with the 37N Cam.
As you will see below the shoes were wearing thin and it was about time
But the surprise damage was that damage done to one of my cam bearings ? you can see the steel being literally eaten around.
My Indy said this is rare, but it happens sometimes from Factory problems in heat treating.
check the scary photos , the first one shows the difference between the front 'worn out' one and the rear that looks kinda of OK (still has slight wear but at the top), the red arrows shows you the one wearing front and the other one not wearing out.
this one shows how the wearing starts on one side of the bearing
Finally both my shoes were worn off equally, very close to the limit, I say the 40K miles was about right for replacing, again remember, this is 36K miles.
I replaced the Oil pump as part of the kit, I really hope that does it. and yes it is a scary thought !
What is more scary, is a full failure of this bearing. that is a good 3-4K$ damage
Seeing this was very scary actually, I hope there is nothing else going bad there
I am looking forward to all this 37N fun, but I will have to wait till the snow starts flying and then stops , in the mean while I have to move, get married, and all that jazz. sigh..
Peace.
Received 23,633 Likes
I replaced the cam chain tensioner shoes on my '06 at 25,000 miles, when I went to Headquarters cams, and expect to continue to replace them at 25,000-mile intervals. No big deal, I just plan it into my maintenance program. The shoes are inexpensive, and H-D is long past producing the problematic ones. I just never saw the need to go to the expense of switching to hydraulic tensioners or gear drive. But I can see where it's worth it to some for peace of mind.
Just keep an eye on the bearings, It is not 'common' but it does happen as evident in the photos .
