Help polishing forks
I recently sanded and polished my lower fork legs on my 98 heritage. looked awesome in the garage but i wheeled it outside today and it looks like crap. i can see all the scratches. not sure what i did wrong. i used 150,250,400,800,1000,1200,2000 then finished with 3000. i started to wet sand with the 800. any suggestions? i used blue magic metal polish to polish them after all the sanding. Im kinda bummed any advice would be great. thanks
DarkTrak is right. I started to make the same mistake and realized what was happening. 150 is too aggressive. Using paint remover first gets rid of the clear coat better then lower grit paper.
Test in a spot that is obviously rough looking. Try 800. If that does not get rid of the deeper scratches then 400 will. Then work your way back to 2000.
Looks like polished aluminum. Not as shiny as chrome, but much better then the clear coat imo. Also, if you get a nick or scratch on the forks - you just sand and polish that spot out. Cant do that with chrome. lol
https://www.hdforums.com/forum/softa...nd-pads-3.html
https://www.hdforums.com/forum/chass...ml#post5324986
