FXSTB Night Train Wobble/Shimmy
Old 02-04-2011, 11:44 PM
DieselSOGMC's Avatar
DieselSOGMC
DieselSOGMC is offline
1st Gear
Default FXSTB Night Train Wobble/Shimmy
I have a 2009 FXSTB Night Train, the Harley Shop can't seem to get rid of a slight but noticeable and aggravating wobble or shimmy from my handle bars. It starts on deceleration at about 53MPH and the handle bars shimmy/wobble. Also in turns there is a slight wobble as well.
The Harley shop has done the following!
Replaced Tire and with that the direction of tread.
Replaced neck bearings.
Tightened to speck the neck bearings.
Replaced front wheel
Inspected wheel bearings.
Still can't get rid of slight but noticeable wobble, yes still under warranty.
No run out on a mag correct? are any other night train owners experiencing this?
Old 02-05-2011, 12:02 AM
DyNaBoB's Avatar
DyNaBoB
DyNaBoB is offline
do the fall away on it or...did you just replace the front tire?....a new tire can take a wear in ...or its got a cup in the tire???.....dont be worried mine had it when i dropped the front end thought it was from that... ended up just being a new tire that needs a break in....
Old 02-05-2011, 12:08 AM
DyNaBoB's Avatar
DyNaBoB
DyNaBoB is offline
could be a balance prob or air pressure ....also
Old 02-05-2011, 12:17 AM
eisterd's Avatar
eisterd
eisterd is offline
Old 02-05-2011, 01:02 AM
Smug's Avatar
Smug
Smug is offline
I had the exact same problem. Two things eliminated the wobble 100%
Front tire re-balanced, took some of the wobble out.
Disregard the spec. for the neck bearings and make them as tight as possible. My front end has absolutely no wobble, is rock solid and tracks true and straight.
You will be on your own if you choose to do this. The dealership won't do to liability concerns. Get yourself a tube of synthetic grease and pack the neck until it oozes out the top and bottom.
Old 02-05-2011, 06:46 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
Dyna beads in the tire and air pressure is important try increasing 3 lbs and down 3 from where you are and see if it changes anything. Mine will do it if the ft tire is a little low on air
Old 02-05-2011, 09:43 AM
back again's Avatar
back again
back again is offline
Received 4,958 Likes on 2,177 Posts
More than likely a bent rotor.It doesn't take much .I had the same problem on 2 different bikes.Seems to be more of a problem with the stock 1 piece rotors.
Old 02-05-2011, 12:13 PM
Ash16's Avatar
Ash16
Ash16 is offline
Haven't experienced anything like that but make sure they take care of it while it's under warranty. Or maybe try a different dealership. Let us know what you find out.
Old 02-05-2011, 12:16 PM
Ash16's Avatar
Ash16
Ash16 is offline
Also I went from a Dunlop 407f to a 408f which changed directions of the tread and didn't notice a bit of difference.
Old 02-07-2011, 02:06 PM
razorback84's Avatar
razorback84
razorback84 is offline
I had a wobble in my front end. Changed out the tires and it went away.
Quick Reply: FXSTB Night Train Wobble/Shimmy
