Danny Gray seat on rocker C with after market HD passenger seat
pics
RocketRocker the first pic i posted is the system they don't have the seat on this one so it can be used as a luggage rack. the bad part it is made for the Rocker and so the paint on it is the matte gray. the second pic is my seat and bike.
Rocker UAE so your saying you didn't mod the danny gray mounting bracket? the strut system is cutout and goes over mounting bolt holes so not a clean fit.
I was wondering the same thing when I bought the Danny Gray, and it looks to me like it will work. I never bothered to bolt it on since I changed the seat, but I did hold it in position. It looked like if I used a washer in the aft position as a spacer, and put some tape over the rear tab and washer to prevent scratching, it would bolt down. To have the passenger struts chromed was expensive, the are very rough casting and took a lot of work to prep for plating.
Re: seat, chrome info
i paid $274 to get the arms chromed in tennessee. from Harley, they were powder coated primer to let you paint them to match your Rocker, not the C. the chrome guy said it took a lot of time to strip the powder coat, and then the arms are forged steel with all the metal flow lines left due to the forging. they are not cast iron. he then had to sand/polish much extra to get the metal smooth, then 6 copper plates, the buff again, before the nickel and finally chrome. they are however perfect and you can see yourself in them. i made a stainless sissy bar, patterned after the little Vrod bar that Harley tells you to use. now (not in pic) a Mustang back pad for the Vrod bar. it is much wider than the Vrod pad. it doesnt look so good, so when i am by myself, i change to the Vrod pad. it looks much better. OH, almost forgot, i have a Rocker seat, it is much-much better than the Rocker C seat. it has padding where the pillion is stored.
just my 2 cents. oh, i me just my $274.00!
pat in tennessee
pat in tennessee
I cant access my photobucket coz of the crappy signal here in china but here are some photos in the below link where I used this setup
https://www.hdforums.com/forum/softa...days-pics.html
No modding at all I did exactly what taconite said and used a washer in the rear hole. I did take the allen key with me and checked if it came loose after a while on the road but i didnt need it.
taconitehead, rocker uae and pturner I'll give that a shot. when you did this did you ever ride anyone on the seat or just use it for luggage?? seems to me that with the DG seat the new struts dont sit down on the square bolts flush? thoughts? thanks for the info and i think I will have them chromed as well.
