Crossbones pinstripes
Old 03-02-2011, 07:40 AM
brettnbama's Avatar
brettnbama
brettnbama is offline
Default Crossbones pinstripes
Does anyone out there know for sure what kind of paint HD uses for the pinstriping on a Crossbones? I thought someone said it was House of Kolor, but I can't find it. I would like to get a perfect match. Being an aspiring pinstriper, I know the HOK pinstripe paint comes in a flat, most others you have to add flattening agents
Old 03-02-2011, 08:15 AM
lp johnny's Avatar
lp johnny
lp johnny is offline
I thought I read that it was tape stripe under clear...now for you denim guys..which I love the denim, under the flat
Old 03-02-2011, 08:33 AM
Rakthi's Avatar
Rakthi
Rakthi is offline
Yup, it's a decal under the clearcoat
Old 03-02-2011, 09:27 AM
rowdy82's Avatar
rowdy82
rowdy82 is offline
Yeah everything on the tank is decals, thats why i had to take mine all the way down to bare metal to repaint it.
Old 04-10-2011, 09:19 PM
mbuff's Avatar
mbuff
mbuff is offline
Default Crossbones Roland Sands fender painted to match.
I think they are silk screened on at the factory. I just had mt fender painted and the painter made a stencil to make the pinstripe and just trial and error on the paint matching.
Attached Thumbnails Crossbones pinstripes-img_2153-a.jpg   Crossbones pinstripes-img_2155-a.jpg
Old 04-10-2011, 10:45 PM
SMF's Avatar
SMF
SMF is offline
just use one shot bro mine matched up perfect
Old 04-11-2011, 09:07 AM
Skeezmachine's Avatar
Skeezmachine
Skeezmachine is offline
Decals under clear coat. If you look real close out in good sunlight you can actually see an outline around the actual colored stripes that indicates that actual edge of the decal.
Old 04-11-2011, 07:57 PM
mbuff's Avatar
mbuff
mbuff is offline
I looked really hard at the pinstripe on the tank today and I didn't notice the outline before.
But I see it now. Skeez is right on.
Old 05-13-2011, 10:52 PM
eljefe6's Avatar
eljefe6
eljefe6 is offline
4th Gear
Rakthi, what kind of fenders do you have on your Crossbones?
Old 05-14-2011, 12:37 AM
Rakthi's Avatar
Rakthi
Rakthi is offline
The rear is from a Fatboy (later than 2007 because of the 200 tire) almost a direct bolt on.
Skeezmachine did a great write up on how to do it: https://www.hdforums.com/forum/softa...nder-swap.html
If you want to keep the springer seat, you need to drill an extra hole in the fender for the bolt that holds the battery cover in place. (best to do this before you have it painted)
The front fender is from a Springer Heritage. Here is the link to a topic on it, it contains more links, one of them with the list of parts you need:
https://www.hdforums.com/forum/softa...ml#post7777507
Hope this helps.
chaselee
05-16-2017 10:23 PM
Rasconzo
Powdercoat & Paint
03-11-2013 06:34 PM
Muddyape
02-01-2010 01:39 AM
HDChloe
01-11-2009 10:45 PM
jmpancoast
12-11-2008 08:48 AM
Quick Reply: Crossbones pinstripes
