Air filter and Power commander
Old 03-15-2011, 08:13 PM
TheNameIs"B"'s Avatar
TheNameIs"B"
TheNameIs"B" is offline
Like another member said, call Jamie at Fuelmoto. They can have you set up in a jiffy. They sent me my AC and Power Commander already programmed. Simply plug and ride, no issues at all. There are other options as you will see looking through the forum, but Fuelmoto makes it easy and affordable. Good luck with whatever you decide.
b
Old 03-15-2011, 08:20 PM
stromboli725's Avatar
stromboli725
stromboli725 is offline
2nd Gear
Arleness big sucker kit is a good bang for the buck as well can use your "football" cover or run it with no cover at all, weather permitting of course it goes for about 100.00 and comes with everything needed to install. Alot of air cleaners out there require you to get a breather kit and carb/efi bracket as well so keep an eye out for that.
Old 06-26-2011, 05:40 PM
The Big TD's Avatar
The Big TD
The Big TD is offline
1st Gear
Well after a long abscense (due to military obligations) I finally have an update for you! haha.
I went with the Arlen Ness "Big Sucker" AC, PC V, and bought Rush's 2" slip-on mufflers
the dyno showed +14.5hp/10tq!
Thanks for all the help!!
Old 06-26-2011, 06:16 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Well done, Welcome home, and thank you for your service to keep us free.
Old 06-26-2011, 06:29 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
I have the Arlen Ness Big Sucker I and yeah, it's a good deal.. air filter covers are of course everywhere.. unless you get creative with your football cover ..and just because I can, i will post these photos a thousand times over and not get tired of it..
Old 06-27-2011, 12:28 PM
Austin Dave's Avatar
Austin Dave
Austin Dave is offline
sorry I don't mean any harm, but I was searching 'air filters' trying to find out if the filter on my ride is 'washable' or not. Looks exactly like pictured filter on Sgt Jims post. I have a '03 FXDL and previous owner musta put on a Screaming Eagle air filter.....sez that on the cover. SM manual sez to wash the filter, but mine isn't the OE pictured in the SM so rather then do some thing stupid, I thought I'd ask....OK? Thanks
Old 06-27-2011, 02:07 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
if it's a K&N style filter, then they make a cleaning/recharging kit for it that'll take care of it for you
http://www.knfilters.com/clningacc.htm
Old 06-27-2011, 03:51 PM
Austin Dave
The mounting plate has the H-D emblem embossed at the 12 o-clock position and sez; "For H-D Twin Cam Covers only." One side of the rubber mount has AO55E4 and the other mount has AO63A4. The filter itself is stuck in/melted into those rubber mounts. There are no brand IDs anywhere other than on that steel plate. Thanks for the response.
Old 06-27-2011, 06:08 PM
Austin Dave
Took the filter to the local HD store. The filter is a Stage 1 Screaming Eagle kit. Filter is a K&N made for HD. Cleaned it real well and re-sprayed. It's all good now. Thanks
KillerBee
03-20-2015 10:45 PM
Parshdude
VRSC Models
05-30-2011 11:14 AM
steve54
Exhaust System Topics
10-17-2010 10:12 PM
cornstalk
06-27-2010 03:11 AM
wydopn231
02-29-2008 07:39 PM
Quick Reply: Air filter and Power commander
