Power commander?
Old Jun 23, 2010 | 07:36 PM
cornstalk's Avatar
cornstalk
2nd Gear
Default Power commander?
I have been told I need a power commander because of Rush slip ons and high flow filter. How do you know which one to buy? Are they pre programmed? I am really not sure if I have a high flow air filter. I have a factory Harley air cover but the black housing on the back side has been removed. I bought the bike this way. Is this considered a high flow filter? Any help would be appreciated. Thanks!
Old Jun 23, 2010 | 08:44 PM
roadkingharry's Avatar
roadkingharry
What year and model bike do you have? It's EFI right? Did you take the filter off to try to identify the manufacturer and part number of it? I had a power commander on my Road King, worked great. You download a map (based on your intake, exhaust and engine mods) off their website into your computer and then load it into the power commander which connects to your ECU. www.powercommander.com for more info.
Old Jun 23, 2010 | 09:31 PM
Great Gazoo's Avatar
Great Gazoo
Do a search in the forum. You will be overwhelmed by the information on this subject.
Old Jun 23, 2010 | 10:11 PM
Heritage632's Avatar
Heritage632
Had a Power Commander III installed and Dyno done by the dealer two years ago and the bike runs great! Huge improvement!
Old Jun 23, 2010 | 10:21 PM
phrogflyer's Avatar
phrogflyer
can you ask the previous owner if he had the stage 1 air cleaner put on? this would surely answer that question. as far which pwr com to get if would depend on year/make of the bike. when all that is figured out i would highly recommend getting it.
Old Jun 23, 2010 | 11:20 PM
Elgin47's Avatar
Elgin47
Go here:
http://www.fuelmotousa.com/
They'll have the right answers to all your questions and can send you a pre-programmed PC for your specific application.
Old Jun 24, 2010 | 12:48 AM
ChromeJunkie's Avatar
ChromeJunkie
Is the filter round or oval shaped? If it is round, it is probably a high flow filter and if it is oval, chances are it is stock.
Old Jun 24, 2010 | 07:44 AM
Swilkins's Avatar
Swilkins
If it's EFI, does a light come on after it ides for a few minutes after you start it up? I put V&H duals on my Heritage and it required a PC which came preprogrammed and with a disc to enable changing the maps if any additional mods were done.
Old Jun 27, 2010 | 03:11 AM
ASPHALT WARRIOR's Avatar
ASPHALT WARRIOR
i got my bike with slip ons and a k & n air filter and i knew it was running lean and hot , well i just put on the power commander 5 and omg its like night and day , runs alot cooler and pulls like crazy now , i am going to save up for the auto tune and life will be good lol good luck but jamie at fuel moto is the best
KillerBee
Mar 20, 2015 10:45 PM
uncle kebo
Feb 11, 2014 06:41 AM
The Big TD
Jun 27, 2011 06:08 PM
wydopn231
Feb 29, 2008 07:39 PM
OCD
May 17, 2007 06:44 PM
