07 Heritage oil cooler install question
Old 06-01-2011, 09:27 AM
VAB-Heritage's Avatar
VAB-Heritage
VAB-Heritage is offline
Stage I
Default 07 Heritage oil cooler install question
I have the HD oil cooler to install on my 07 Heritage. do I really need to drain the oil to install? I just changed it about 200 miles ago, so I would like to be able to install w/o the oil being drained, or will the oil all drain out when I take off the oil filter? thanks for the help!
Old 06-01-2011, 09:51 AM
TheTroupe's Avatar
TheTroupe
TheTroupe is offline
Yes oil will come out when you remove the filter.
Old 06-01-2011, 03:27 PM
oct1949's Avatar
oct1949
oct1949 is offline
Don't really know, I alway drain the tank first. thinking wihout the motor runing U'd just loose whats in the filter,, Just not sure.. never seen this question before.
Old 06-02-2011, 07:00 AM
zoood's Avatar
zoood
zoood is offline
Former Sponsor
Just drain your oil in a clean container. It's no big deal. I use a plastic 1 gallon oil container with one side cut open. With only 200 miles on the last oil change. You can reuse the same oil filter too.
zoood
Old 06-02-2011, 04:21 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
VAB,
I just finished installing an oil cooler and was asking the very same question, "Will the entire contents of the oil tank drain out if the oil filter is removed?" Couldn't find an answer and didn't want to make a mess or lose my fresh oil experimenting. Ended up draining the tank and re-using the oil.
Old 06-02-2011, 05:12 PM
cpiad's Avatar
cpiad
cpiad is offline
Account Closed
Drain it or you will have a mess.
mjonesjr84
06-23-2016 08:50 PM
LocoPilot750
07-14-2011 07:02 PM
LocoPilot750
12-07-2010 07:34 PM
pcbunn
08-28-2010 06:47 PM
DocHarley
11-02-2009 09:14 AM
Quick Reply: 07 Heritage oil cooler install question
