What wheel bearings did you use on your Rocker?
Old 02-17-2012, 04:49 PM
HeHateMe's Avatar
HeHateMe
HeHateMe is offline
Default What wheel bearings did you use on your Rocker?
Read about bearing failures on Rockers. What bearings did switch too if yours failed or if you did it to prevent future failures?
Old 02-17-2012, 05:37 PM
LaidInk's Avatar
LaidInk
LaidInk is offline
All ***** are an option
link to j&p http://www.jpcycles.com/product/203-785
Old 02-17-2012, 05:45 PM
HeHateMe's Avatar
HeHateMe
HeHateMe is offline
Thanks
Old 02-17-2012, 05:52 PM
LaidInk's Avatar
LaidInk
LaidInk is offline
Timken is also an option I believe the part number is 205PP if I remember correctly, but I'd have to pull my wheel off to confirm that can't remember if the hub is 52 mm or not axle is 25mm tho
Old 02-17-2012, 10:28 PM
Rodzilla6's Avatar
Rodzilla6
Rodzilla6 is offline
I put Timken in mine, but All ***** work fine also. My rocker had 2 rear bearing failures in 15 thousand miles, the second caused 1200 bucks damage and almost got me killed (65 mph on a corner by a cliff and no guard rail...). It is not just rockers, all bikes after 08 have the challenged bearings...ditch them asap!!
Old 02-17-2012, 11:13 PM
HeHateMe's Avatar
HeHateMe
HeHateMe is offline
Man thanks for sharing that. I'm definitely going to change them on all my bikes now.
Old 02-18-2012, 07:44 PM
Rodzilla6's Avatar
Rodzilla6
No problem. The good thing is that a whole new set of high quality bearings is only about 30 bucks!!!! And about 20 bucks per wheel to install. Cheapest life insurance you can buy! Other than the bearings, I LOVE my Rocker!!!! It's going nowhere!!!
Old 02-18-2012, 08:28 PM
waldhorn's Avatar
waldhorn
waldhorn is offline
Now that I'm worried about bearings...Doesn't Timken make Harleys bearings? Were your bearings leaking before they failed. Just wondering.
Old 02-18-2012, 11:19 PM
LaidInk's Avatar
LaidInk
LaidInk is offline
As of 08 Harley switched to China made bearings
Old 02-19-2012, 12:23 AM
waldhorn's Avatar
waldhorn
waldhorn is offline
Sooooo. Don't get the bearings from Harley? Now you have me very interested. At least the one thing rocker owners have to learn, is how to research. It used to be except, now its discontinued. Am I at the wrong site?
Quick Reply: What wheel bearings did you use on your Rocker?
