How do I know if my bike has Stage 1 download?
Old 04-09-2012, 07:01 PM
Manobeer's Avatar
Manobeer
Manobeer is offline
Default How do I know if my bike has Stage 1 download?
2004 Heritage.
Purchased used
I recently got a Power commander and want to try out a few different maps, they vary for stock ecm and stage 1 ecm.
Is there a way for me to find out if this bike has the download installed?
I posted in the correct forum, 150 views later no replies... So I was hoping someone here could help.
Thanks
Old 04-09-2012, 07:08 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
hard to say, check to see where the rpm limiter is. If it has stage 1 it would be 6250 or 6500 rpm thats all stage 1 really does. Or take the bike out and see where itkicks in that would tell you. at 6500 then yes it does
Old 04-09-2012, 10:32 PM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
Try the map for stock then try the map for stage 1. See which runs better and go from there.
The Fatboy I recently picked up had V&H straightshot slip ons and a Fuelpak. I replaced the pipes with some a bit quieter we pulled off my g/f's Fatboy a while back. No markings or other id so I've no idea what they are. Fuelpak tech suggested a starter map I plan to try out this weekend.
Old 04-10-2012, 05:59 AM
oct1949's Avatar
oct1949
oct1949 is offline
Or call the Org owner, If U know what dealer the bike was taken to, U could also call them. They should be able to look at the past service records.
Old 04-10-2012, 10:40 AM
str8jacket's Avatar
str8jacket
str8jacket is offline
If any work has been done at a Harley dealership, you don't need to know what dealership did the work. Any work that was done at any Harley dealership is on record and can be looked up at any dealership.
Old 04-10-2012, 11:07 AM
relxn88's Avatar
relxn88
relxn88 is offline
Originally Posted by Manobeer
2004 Heritage.
Purchased used
Thanks
Once you put a map in the Power Commander, hit control-F and see if rev x-tend is enabled(or even available with the software in your PC), if it's enabled, unclick it. Then take your bike out and if it revs over 5500, you have a Harley download in your ecm and you can use the stage PC maps. If you have trouble getting over 5500, your ecm is stock. Re-install rev x-tend in the PC and you should be good to go on the stock ecm maps.
Old 04-10-2012, 11:22 AM
toxicstang99's Avatar
toxicstang99
toxicstang99 is offline
My personal experience when I put my VnH fuel pack is I had to take it in. I tried to give them the bike info and they couldn't run it. Maybe they were idiots, but I had to take it in.
blueduramax
04-06-2010 12:32 AM
mike06train
06-30-2009 04:52 PM
HB
Exhaust System Topics
09-14-2008 09:54 PM
eagle1eye
07-13-2008 04:52 PM
manowar
08-16-2006 01:07 AM
Quick Reply: How do I know if my bike has Stage 1 download?
