map download question
Old Aug 15, 2006 | 10:03 PM
manowar's Avatar
manowar
Default map download question
i have a 2006 sg and i just put the pc usb and hooker tuned flow slip ons and a kn air filter assembly.
the map says for hooker slips ons left to torque right to hp wiht a stage 1 ecm and se airfilter.
im confused about the stage 1 ecm ? do i need to do something to my ecm?
or do i know have a stage one due to the mods i just did?
Old Aug 15, 2006 | 10:10 PM
klovelace's Avatar
klovelace
4th Gear
Default RE: map download question
STAGE 1 ECM IS IF YOU TAKE THE BIKE TO THE DEALER AND HAVE THEM DOWNLOAD THE STAGE 1 PROGRAM FROM HARLEY DAVIDSON
YOUR ECM SHOULD ALWAYS BE STOCK UNLESS YOU HAVE THIS DONE
PhilM's Avatar
PhilM
Stage I ECM means a dealership updated the control code on the bikes computer. Sometimes they do it, sometimes they don;t unless you ask for it.
The Stage I air filter is not the same as Stage I ECM.
A PC map for a bike with like hardware + a Stage I flash, might not be quite right on a bike w/o the flash, but it would not hurt to try it.
Hope that's what you were asking...???....
Old Aug 15, 2006 | 10:11 PM
manowar's Avatar
manowar
ok so the map i would need would be for a stock ecm i never bought my bike back to the dealer after i picked it up the first day i do not trust them at all. so i would assume my ecm is stock correct?
and thank you
Old Aug 15, 2006 | 10:38 PM
Basz's Avatar
Basz
ORIGINAL: manowar
and thank you
Yes you have a stock ECM.
I do have a related question - Does the PCIII with the correct map to a stock ECM negate the need for a Stage I download from the dealer?
Old Aug 16, 2006 | 12:28 AM
Comfortably Numb's Avatar
Comfortably Numb
I am of the belief that the Stage 1 download allows the bike to rev to 6200 rpm. (?)
I recall that Dynojet now has an additional program to duplicate the feat for those with the stock ECM.
CN
Old Aug 16, 2006 | 01:07 AM
alazlo's Avatar
alazlo
Just had my pcIII dynoed.. Used a downloaded map before that . my map was for stock ECM, mitre cut Sampson pipes and hi flow. That map negated the need for a download. I also had them raise my rev limiter while they were at it. I would reccomend a dyno tune at your earliest convenience. Even though my map was close and the Dyno tune only took 30 minutes, cost me a well spent $70.00, and it made a lot of difference...
blueduramax
Apr 6, 2010 12:32 AM
mike06train
Jun 30, 2009 04:52 PM
jhr
Mar 4, 2009 09:41 PM
eagle1eye
Jul 13, 2008 04:52 PM
mark2004RK
Nov 6, 2006 11:04 PM
