Steering Head Bearings
Old 06-17-2012, 03:07 PM
Andy-Deuce's Avatar
Andy-Deuce
Andy-Deuce is offline
Default Steering Head Bearings
These are the triple trees of my 2002 deuce, i'm replacing them with raked triple trees. My Question is can this lower bearing be removed and reused onto the stem of my new triple trees? Was the bearing pressed on originally and if i to buy a new bearing does it need a special tool to press it on?
Old 06-17-2012, 03:29 PM
TRUSTNOBODY's Avatar
TRUSTNOBODY
TRUSTNOBODY is offline
Nope it cannot be reused. U can get a new timken bearing from ebay for a couple bucks
Old 06-17-2012, 03:30 PM
TRUSTNOBODY
The new bearing will slide on new stem without having to press it on.
Old 06-17-2012, 03:42 PM
ghostrider69's Avatar
ghostrider69
ghostrider69 is offline
I have reused the bearings many times in the past with no issues what so ever as long as it is being reused in the same race. It should slide off but sometimes may need a little persuasion. I have used a press to press the stem out through the lower tree and the bearing will be left sitting on top of the tree.
Old 06-17-2012, 03:52 PM
trozenhorse's Avatar
trozenhorse
trozenhorse is offline
for the cost of the bearing replace it while you have the chance. I had to get mine pressed on. Good luck!
Old 06-17-2012, 05:11 PM
jreichart's Avatar
jreichart
jreichart is offline
IMO, replace the bearings while you've got it all torn down. You can get a good set for $30-40. Inspect the races and replace them too if needed. Most aftermarket trees don't require the bearings to be pressed on, just a slip fit, but I do believe they are pressed on the stock trees.
Old 06-17-2012, 05:36 PM
Ash16's Avatar
Ash16
Ash16 is offline
I agree with J. They're cheap and it's probably about time to replace them anyways.
Old 06-17-2012, 07:01 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,416 Likes on 455 Posts
+1 It's a very slight press fit. You can use a small arbor press to do it. Don't need a hydraulic press.
Old 06-17-2012, 08:32 PM
jreichart's Avatar
jreichart
I'm confused, why wouldn't you replace them? Would you change cams and use the same bearings? Do you reuse your oil if it looks pretty good? Bearings are cheap, relatively. Who wants to tear down their front end again if they can avoid it? It's like o rings and gaskets, why do things twice. Just replace them. JMHO.
Old 06-17-2012, 09:34 PM
WFA's Avatar
WFA
WFA is offline
Originally Posted by jreichart
i'm confused, why wouldn't you replace them? Would you change cams and use the same bearings? Do you reuse your oil if it looks pretty good? Bearings are cheap, relatively. Who wants to tear down their front end again if they can avoid it? It's like o rings and gaskets, why do things twice. Just replace them. Jmho.
I couldn't agree more. If you have it down to put new raked triple trees on why would you not replace the bearings and the races. The races generally take as much of a beating, if not more, as the bearings. Imo... both will have more pressure on them due to the rake. I would go all new. Cheaper now !!
Quick Reply: Steering Head Bearings
