need some torque specs please
10-13-2012, 03:49 PM
Can someone post up the torque specs for a 2009 Crossbones front axel, and the two bolts on the bracket that holds the brake caliper. One is a torx head, the other is an acorn nut on one side and a six sided nut on the other. It is the one that connects to the little arm that runs to the back part of the fork leg....thanks in advance.
10-13-2012, 06:25 PM
Axle is 60 - 65 ft/lbs
The acorn stud: 31 - 35 ft/lbs
The upper caliper mounting bolt: 25 - 30 ft/ lbs
Manual mentions to use a new spring pin and washer.
So any pictures without front fender forthcoming?
10-14-2012, 06:19 AM
yep...there was a post on here a few days ago with a pic from the service manual, but now I can't find it.....thanks for the torque specs
10-14-2012, 11:00 AM
got in there to pull the front axel and chickened out!!! the only sized socket I could get to fit was a 24mm, does that sound right? If it is standarsd, I don't know that I have one big enough.
10-14-2012, 05:39 PM
Back down the torque on your wallet by about 15# so you can open it and buy a service manual. Best investment you'll ever make.
10-14-2012, 06:31 PM
yeah thanks for the advice. I have one, but my garage stuff is still pretty much all packed up.
10-14-2012, 08:14 PM
It's probably 15/16", like my Fatboy's front axle -- an odd size.
My rear wheel is 36mm, which apparently is normal for rear wheels... I've heard all to do with wheels & brakes are normally metric.
10-14-2012, 08:43 PM
Quote:
Originally Posted by
spydyr
What he says ... 15/16" for the front axle and 36 mm for back axle on the Xbones. (24 mm and 15/16" are practically same size anyway)
You might also pick up a new locknut for the front axle as recommended in the manual. Part number: 7994
MyFavRk
02-10-2019 06:49 AM
Kongbastard
06-22-2016 11:05 PM
priceamp
Ironhead
08-12-2014 10:09 PM
ExDucRider
10-14-2013 03:22 PM
yowflhtk
Wheels/Tires
09-21-2012 08:10 AM
