Loctite on engine & transmission mounting bolts?
Old 05-16-2013, 09:54 AM
rpmpit's Avatar
rpmpit
rpmpit is offline
Default Loctite on engine & transmission mounting bolts?
Have heard many different opinions on this. I'm talking about the 4 bolts that mount the engine (EVO) to the frame and the 5 studs/nuts that mount the transmission to the frame. Shop manual doesn't mention loctite in either case.
Old 05-16-2013, 10:57 AM
jam436's Avatar
jam436
jam436 is offline
Question is, why wouldn't you?
Old 05-16-2013, 12:06 PM
rpmpit's Avatar
rpmpit
rpmpit is offline
I would. Just curious why its not specified in the manual??
Old 05-16-2013, 12:15 PM
louie c's Avatar
louie c
louie c is offline
because any where there is heat loctite stays liquid.
Old 05-16-2013, 12:20 PM
rpmpit's Avatar
rpmpit
rpmpit is offline
Edit: But what about loctite used on cylinder head bolts and other internals??
Old 05-16-2013, 12:22 PM
louie c's Avatar
louie c
louie c is offline
Originally Posted by rpmpit
Yeah, this is along the lines of what I was thinking. So is there an alternative or just torque and check at regular intervals??
does the manual talk about lock washers ? if not just torque the bolts.
Old 05-16-2013, 12:25 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Sure if you never intend to take the thing apart. Head bolts are lightly oiled and torqued. I anti seize my engine mounting bolts.
Old 05-16-2013, 12:27 PM
soft 02's Avatar
soft 02
soft 02 is offline
Not true. Absence of air will set the loctite not lack of heat.
Old 05-16-2013, 02:16 PM
Snowyone's Avatar
Snowyone
Snowyone is offline
Default loctite
Some habits are good and from my days of riding shovelheads external stuff gets Loctite. If I didn't it usually wasn't there by the end of the day. I definitely wouldn't use it on headbolts cause it would be difficult to get an accurate torque. I would deffinately use it on your mounting bolts for engine and tranny mounts just for piece of mind. It really ruins your day to have a stud come loose on the tranny. As for getting them loose make sure you use the right product to start with and a little heat helps. Know there are different grades like blue for most fasteners that will possibly be removed again in their life time. Red is for serious holding when you think you'll never take it off again and if you do heat helps. Green is you're not going to take it apart without a lot of cussing and throwing stuff around. And the book does call for Loctite occasionally. Cam sprocket bolts come to mind for tc.
Old 05-16-2013, 02:42 PM
rpmpit's Avatar
rpmpit
rpmpit is offline
Thank you! So blue for engine and tranny mounts??
Quick Reply: Loctite on engine & transmission mounting bolts?
