First problem on my Breakout
First problem on my Breakout (updated with video)
I had about 1K miles on my Breakout and started to hear an awful grinding noise whenever I turned the ignition switch on. The grinding noise is so loud that it feels like something is going to break. The fuel pump on my Breakout used to make a high pitch sound when it was priming. The bike runs fine though. I drove it around for a few minutes but I can't hear the pump over the running engine. Once I got home, I turned the switch on, and the fuel pump was grinding. Sounds like she's sick. I'm impatient because the weather was finally nice so my wife and I went on a 200 mile run. After about 2 hours or so of riding, turn the ignition on and the fuel pump sounded fine. Normal priming noise. Thought all was ok. I even stopped a couple of times on our ride just to check for any pump noise and all was still ok. I got home, shut the engine off. I let the bike sit for a couple of hours, and still the pump was quiet. However, this morning after the bike sat overnight in my garage, I turned the ignition switch back on, and wow, the fuel pump is grinding away. That sux. It's kinda weird how the fuel pump primes fine when the engine is hot and its so awful once the bike gets cold. I know what's going to happen when I take it to the dealer. I'm going to ride the bike there and the fuel pump is not going to make any unusual noise because the bike will be hot. Get it home, sit over night and crap, it will sound awful again. Is this bike going to break on me? Looks like I will have to take it to the dealer and leave it there overnight so they can try it in the morning. Oh, the noise in positively in the gas tank because I placed my hand under the tank, and that's where the noise is coming from. Fuel tank level doesn't seem to have an affect on it. The pump made that grinding noise either way and anytime the bike sat around for a while, like over night. Anyone have any thoughts on this?
thanks
thanks
I can use my phone to record the noise from the pump. I just didn't want to be told "no problem found". The bike needs to be cold in order to verify the problem. I know the dealer will not have the part in stock so I will be out of my bike for about a week or more. I wish my truck was big enough to fit my Breakout I would just take it there so the dealer could easily say " yup, you need a new fuel pump". Order the part, take my bike home and ride it in when the part comes in.
I recently just had the same issue i think ... I went to the run position and instead of the nice soft sound of the fuel pump it was a very loud noise ... I tried it again and it did it as well .. after a short run time it was fine and it has not done it since ??? I only have 344km on her
