I was getting ready to fab a side mount license plate bracket and when I went to loosen the rear axle nut I found I didn't have anything that would fit it. It looks different from all the other axle nuts I have seen; instead of using a standard wrench it's a round nut with a hex center. When I measured it with my caliper it was ~19mm. The largest size I could find at any store was 17mm... Sears, tractor supply, home depot and lowes all struck out. Any ideas?
Just got back from Harbor Freight, they had an impact socket set that included a 3/4" hex socket, which fit perfectly. So for anyone else that needs to know, 3/4" hex is the one you need.
You could also purchase a 1/2" hex cap bolt. It will have a 3/4" hex head. Back it with two nuts to lock them down and use the outside nut to turn with a socket while the bolt head is inserted into the axle opening.
Guess the OP got his answer long ago since his question has been posted more than 3 years ago, lol.
Oh ya Ray, I didn't catch that either lol, but I guess with over 4300 views people are still looking for the answer.... Well, at least we added a couple of tricks to the thread for taking the nut off, maybe it'll help someone down the road.
