Noise in my engine got louder today
Old 07-30-2013, 07:16 PM
Falcon195's Avatar
Falcon195
Falcon195 is offline
Default Noise in my engine got louder today
When I got my 2012 Fat Boy a couple weeks ago I noticed that the engine seemed to be a bit louder than my 2012 Street Glide so I just attributed this to the counter balancer system on the 103B.
But gradually the noise got louder and today the noise was so loud I am convinced that something isn't right. The bike has 800 miles on it so it is still basically new.
The noise I am hearing is rather constant and I can hear it coming more from the front lower at the base of the cylinders more on the left side of the engine around the oil filter. I can hear it all the time (idle or at higher rpm) (hot or cold) and it does gets louder as rpm's go up. I can really hear it going down the road and it seems that above 2500 rpm the noise is most noticeable.
The noise is not a clacking, ticking, or whiring but the sound is a constant machine type noise kind of like a bicycle chain running on the sprockets without any oil on the chain. Like I said this noise is loud and I had a buddy ride the bike and i could hear the noise when he was riding towards me coming up the street, so I am pretty sure it isn't the normal 103B noise.
And yes the primary is full of oil as I checked the level when I got the bike a couple weeks ago, and I have no leaks.
My thoughts are something in the primary is making the noise, maybe a bad bearing or something to do with the primary chain. If the primary chain was loose and rubbing against the primary case I would thing the noise would be more of a clacking noise, but this is just a constant noise.
Any ideas?? I can't get the bike in to the dealer for a week or so. The bike is under warranty but at this point I don't think I should ride it.
Here is a video, you can hear the noise but it doesn't sound as loud on the video, but notice when the camera gets closer the the lower front of the engine how much louder the noise is. This is the noise I am talking about.
Thanks
http://www.youtube.com/watch?v=7wGqS...ature=youtu.be
Old 07-30-2013, 07:26 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
Almost sounds like your are describing the sound of a primary chain hitting the primary.
Open the inspection cover on the primary and check the chain deflection. Maybe the adjuster dropped.
Old 07-30-2013, 07:28 PM
Falcon195's Avatar
Falcon195
Yeah but wouldn't that be more of a clacking noise?
Anyway there is no primary inspection cover to check chain deflection.
Old 07-30-2013, 08:07 PM
Falcon195's Avatar
Falcon195
What are the chances of the counter balancer shaft bearings going bad and making this noise?
Old 07-31-2013, 05:46 PM
liquidr1's Avatar
liquidr1
liquidr1 is offline
Very possible your bearing the balancer chain and bearing noise. The are located inside the engine casings behind the primary. B motors are naturally more noisy due to the balancer system. If it has gotten abnormally loud take to the dealer.
Old 07-31-2013, 06:03 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
I'm stuck in the past. When did they take the inspection cover away? How do you adjust the chain now?
Old 07-31-2013, 06:10 PM
DEW2112's Avatar
DEW2112
DEW2112 is offline
You don't! Their auto adjust, HD doesn't think their customers are smart enough to do it!
Old 07-31-2013, 07:32 PM
Falcon195's Avatar
Falcon195
I did, said it was "normal"
Old 07-31-2013, 07:42 PM
bloomington g's Avatar
bloomington g
bloomington g is offline
Not sure from your video what you are hearing other than the primary...
Old 07-31-2013, 07:44 PM
Falcon195's Avatar
Falcon195
Yeah the video doesn't do the noise justice. But what sounds like the primary seems to be coming from the lower front of the engine. And it is LOUD.
Quick Reply: Noise in my engine got louder today
