best solution for the cam bearing and cam shoe tensioner problem
Old 10-21-2013, 08:06 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Originally Posted by flpete
I know this may of been asked many times before, and i have searched this forum for solutions...BUT !!! Yea I know. I have a 2006 softail deluxe and love the bike. it now has 6100 miles on it. Had a buds softail trash the motor at 9000 miles to to cam chain followers and I am getting nervous about the whole B/S manner in which Harley is disrespecting harly riders in general.
I went to my local dealer and was quoted a price of nearly 1500.00 to do the fix with the new cam plate and bearings setup with new hydloc tenioner set up complete with new oil pump. That is a lot of coin for a man on a fixed income. I know some swear by going the gear route setup from S&S but then there is the crank shift thing.
I can only afford to do this once and want to do it right the first time. To me my deluxe is a piece of art and deserves the very best and I want to take care of it and pass it down to one of my sons.. I have cancer, money is tight....and I want to get this done. My dealer is like just trade the bike but low ***** me on my trade in which is like brand new with new tires and new battery and battey tender.
I live in central florida....can anyone here point me in the right direction and or an indy shop to do the work. A good bud told me to find a good shop and just have the motor rebuilt and adress all of the weak points of the twin cam motor...this kind of bites since the bike only has 6100 miles on it......Please feel free to point me in the right direction.....
many thanks in advance
kindly
ron
I just did the upgrade to my 2005 Deluxe. Use the 96" cam plate and oil pump w/ conversion cams or you have only fixed half the problem. (The S/E came plate/oil pump/tensioner set up only upgrades one of the 2 chains.)
I did the work myself. Cost for parts was about $900 using on-line discount dealers. Included S/E adj. pushrods and new Gaterman lifters, plus the bearing tool, 96" Cam Plate, Chains, gears, conversion cams, hydrolic tensioners, oil pump and associated hardware and gaskets. I got about 20% off on all HD parts and the Andrews cams. It's not too difficult and there are lots of you tube video's and assistance on-line.
As mentioned, your friends problem was unusual at that mileage, and you probably don't need to do it right away. Inspect the tensioners, and make a decision.
Old 10-21-2013, 08:07 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Originally Posted by jreichart
Have em checked. Might be a non-issue for many thousand more miles. I have 50,000 on my 05, and they are still well within factory wear limits. They are starting to pit though, so I do plan on replacing them with new tensioner shoes this winter. I've read a lot about the hydraulic plate and don't feel it's worth the coin. Did the dealer mention you'd need to also replace the cams in order to get a roller chain on the inner side? Otherwise the hydraulic kit reuses the inner link chain, which will continue to eat away the inner tensioner shoe.
Bottom line, check them. The percentage of bad chains is relatively low. For every guy that has had major issues, there are thousands more with many thousand miles on their bike who don't even know what a cam chain tensioner is.
^^^Best advice so far.
Old 10-21-2013, 08:08 AM
magna's Avatar
magna
magna is offline
Originally Posted by klf33
60 K miles is way too high by the way, Mine were almost a disaster at less than 40K miles.. it is the luck of the draw.
and 1500$ including parts and labour is sadly around what I paid, it is your chance to get new cams though.
https://www.hdforums.com/forum/softa...r-averted.html
Looked at his post again, not sure wether the milage is missing a comma or a zero, if its a zero it's definitely in need of new tensioners.
Old 10-22-2013, 04:08 PM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,515 Likes on 6,271 Posts
I just called Sauk Prairie HD in Sauk City, WI. I like their approach. They will inspect the tensioners for $110. If fine, you're done. If they are worn, they apply the $110 to the repair. I plan to have them checked in the spring as I have 25k on my '03 FLHTCUI now.
They only recommend changing the inner can bearing if you upgrade the cam, which I don't plan on doing. I am happy with my current stage one performance.
When the time comes I will do the SE Hydraulic upgrade. Not going to worry until then.
I think it would be crazy to rebuild your engine now, to avoid the risk, of having to rebuild it in the future. Just ride it and enjoy it. If you can't stop worrying just get the inspection.
fjkpan
Engine Mechanical Topics
02-24-2019 07:53 PM
offbeatmammal
12-28-2015 10:26 PM
kiwihog
06-14-2015 08:50 AM
kevdog
05-03-2014 10:18 AM
bruggy
Exhaust System Topics
106
03-20-2008 07:58 AM
Quick Reply: best solution for the cam bearing and cam shoe tensioner problem
