Cam chest rebuild?
Took her to an H-D dealer recently as it was close to where I was working and needed a replacement tire (picked up a nail). They suggested I'd probably need a cam chest rebuild pretty soon (and quoted around $2k). My usual mechanic (who's usually pretty busy so tends not to oversell) wasn't sure but quoted around $1.1k for a rebuild.
Question is ... do I need it, and what should I look out for to tell me if I really should start saving up (also have to replace the transmission on my Jeep - over 100k miles and starting to whine!)
(relatively new to the Harley world after having sport bikes for the last 20 years, and I've never owned a bike for this long so getting into all sorts of unknown territory!)
23.000 miles shouldn't require much attention in there .
I'm in the middle of changing my cams and lifters, upgraded cam tensioners, quickie push rods,gaskets and tools. I spent near $800.00 and doing the work myself.
My outside chain tensioner had minor wear and the inside one looked new.
I have 25K on it.
https://www.google.com/url?sa=t&rct=...uDT14bNzrdAS4Q
If you plan on doing any performance upgrades, the kits available to update your camchest to '07 and up is worth a look.
make sure they replace the cam bearings too.
around here you can get the hydraulic kit dealer installed for about $1200. They recommend checking the tensioners at 30,000 miles, You might want to at least have them checked to be safe but they should be good for at least another 5k
