Blackline fairing
Blackline fairing
Hey guys,
I searched for some time now and I thought i saw a post with an Arlen Ness direct bolt on fairing on a Blackline. I ran into the Nightrod post and a post about Rifle. I stopped into the dealership and looked at one on 2014 street bob, looks like it will work other than fork tube brackets. Tubes on the blackline are 41mm there must be some brackets out there that will work, any idea what will work?
good luck getting them off their loctited on and made on to the rubber mounts. I ended up just getting new stainless steel bolts and acorn nuts and rubber pucks at lowes for like $15. the way I did it was to use the head light cup and marked the three holes then ended up drilling them out bigger then the acorn nuts so they will go thru the back mount. then put the light back together with new nuts, bolts and rubbers then sandwich the headlight between the fairing and back mount had to drill the holes out a little. its a pain in the *** to put back together with the oring on fairing but can be done. I did have to put a washer on each side of the mount on the the triple tree to spread the arms out cause the slots just a little bigger and the fairing would rock at high speed.
