Wheel bearings
Old 03-08-2014, 02:19 PM
rolfsharley's Avatar
rolfsharley
rolfsharley is offline
Default Wheel bearings
Can i put 3/4" bearings on a Wheel from a 2008 that have 25mm bearings?
Old 03-08-2014, 03:13 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,416 Likes on 455 Posts
I don't see why not. I put 25mm bearings in a wheel made for 3/4. I had to do some shopping around to find bearings the proper size. Just find a bearing with the proper ID/OD, and you should be good to go. You may also have to rework your spacers, depending on the width of the bearing.
Old 03-08-2014, 04:54 PM
alcotune's Avatar
alcotune
alcotune is offline
The bearing will fit the wheel but the wheel may not fit on the bike.
I got an '08 wheel and swapped out the bearings to fit my '07 but the wheel didn't line up. This is on a FXST.
Old 03-08-2014, 05:09 PM
xwhyz1959's Avatar
xwhyz1959
That's where the spacer work comes in. I had to shave the one on the caliper side down some, then order another for the other side, and shave some off of it as well. Bike was a 08 FXSTC.
shorty07ultra
10-14-2023 03:46 PM
packrat56
Panhead
04-16-2011 05:47 PM
Rickr01
08-13-2009 11:56 AM
deerslayer1543
Wheels/Tires
08-08-2009 09:12 AM
vetto
Wheels/Tires
01-30-2009 02:37 PM
Quick Reply: Wheel bearings
