Passing Lamps Replacement
After extensive research I replaced my passing lamps on my '05 Heritage with Halogens from NAPA. $31 for two. They are made by Wagner Lighting. Hope this helps everyone.
Here is the p/n and specs:
Part Number: LMP 4416
NAPA Lamps.
Bulb Lumens Rating : Approx. Max C andle Power Primary 35000
Bulb Type : PAR 36 Bulb 4 1/2" (114 mm) Dia
Electrical Rating : Design Volts Primary 12.8
Lamp C andle Power : Approx. Max C andle Power Primary 35000
Overall Diameter : 114 mm
Overall Length : 2.75670 mm
Volts : Design Volts Primary 12.8
Watts : Design Watts Primary 30
Headlamp Bulb C andle Power Rating : Approx. Max C andle Power
Primary 35000
Headlamp Bulb electrical Rating : Design Volts Primary 12.8
Headlamp Bulb Type : PAR 36 Bulb 4 1/2" (114 mm) Dia
NAPA Lamps.
Primary 35000
