Finding Neutral
Old 06-24-2014, 10:47 PM
Dwair's Avatar
Dwair
Dwair is offline
Default Finding Neutral
Hello,
So I've had my Softail Slim for about a week now. I've figured out to start with that I have to have the clutch FULLY depressed all the way to the handlebar to even have a chance of shifting to neutral, but even then I'm having trouble.
I'm not a new rider, but this is my first HD, my last bike was a Honda Shadow, which was never a problem, was easy as pie shifting to neutral from first or even second.
I've found that I actually have to shut the bike off when parking in first gear, and THEN shift to neutral to even get it to, and even then it takes me like 2-3 attempts, and I'm doing it as light as i can, just skips right to second gear.
Trying to figure out, is it just always this hard? I've occasionally got lucky and shifted it to neutral at a stoplight, but its generally only as i'm coasting to the stop point. If I'm already stopped, its not happening.
So is this common with HD? Or what am I doing wrong? I feel like a novice, and not being able to put it in neutral at a stoplight is quite annoying.
Thanks for any help.
Old 06-24-2014, 10:56 PM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
My Heritage was a PITA for at least the first 1000 miles. I've heard a few others say the same thing with new HDs. Sometimes it helps to rock the bike forward and back a little. They do ease up.
Old 06-24-2014, 11:09 PM
Pistonman1's Avatar
Pistonman1
Pistonman1 is offline
Check the clutch adjustment.
Old 06-24-2014, 11:24 PM
One Vision's Avatar
One Vision
One Vision is offline
Same bike, 1300 or so miles on it. Still cant find Neutral very easily until it warms up a bit. And even then it doesnt like it.
I think after the 1k Maintainence and the changing of the fluids, some clutch adjustment etc it will work itslef out. The bikes are always so tight when they are new.
OV
Old 06-24-2014, 11:29 PM
Superrust's Avatar
Superrust
Superrust is offline
Mine was the same way. Give it time and it will loosen up and become easier.
Old 06-25-2014, 12:43 AM
CagelessRoy's Avatar
CagelessRoy
CagelessRoy is offline
When first starting my bike ('13 flstc, 7900 miles), the sequence is usually 2-1-N. My guess is 2-1 relieves some stress so it can find neutral. At a stop light, it's problematic, it either goes in on first attempt or I'm still trying 2-1-2-1... when the light turns green.
Now I did drive a new '13 flstc that really liked neutral, too much so after ending up in neutral when aiming for second three times in 15 minutes. I'll take the hard to get in neutral any day...
Old 06-25-2014, 03:51 AM
CajunIron's Avatar
CajunIron
CajunIron is offline
3,300 miles on the Slim and finally a little love tap and she goes right into neutral. Prior to that it was a pita.
Old 06-25-2014, 06:28 AM
funbikerchick's Avatar
funbikerchick
funbikerchick is offline
I found it very difficult on my Street Bob. On my Heritage it is a bit easier. However, still not a simple thing. For me, to find it, I always go from first with a tap on the heel shifter. Sometimes, actually often, it is first second, first, neutral. Not that I am trying to get into second and back to first, but that is generally what happens. My Heritage has ~ 500 miles on it so maybe it will get easier, but it never did with the Street Bob.
Old 06-25-2014, 07:09 AM
overthehill?'s Avatar
overthehill?
overthehill? is offline
Same here....'14 Heritage. For the life of me couldn't find neutral. A friend suggested while rolling to a stop, down shift to first and then lightly tap the heal. What I found was that it became easier to do this as the miles increased. Now at about 1000 miles I get it around 90% of the time....so hang in there. : )
Old 06-25-2014, 07:18 AM
mjrfd99's Avatar
mjrfd99
mjrfd99 is offline
Received 2,377 Likes on 987 Posts
When ya ride it long enough you'll probably get the feel for stepping it down from 2-N w/o even using the clutch. Our old Sportster is NEVER is good at finding N, our old Shovel is a little better but still can be a bit be tight. Always stepped from 2 to N at correct road/RPM speed. Our 07 Heritage was tight @ 1400 mi when bought - by 2000 mi it was way better and shifts smooth, I still by habit, when slowing just step it out of 2 to N no clutch at the correct road/RPM speed
Quick Reply: Finding Neutral
