FXSB (Breakout) Rear Tire Life/ Replacement
Bought my 2014 Breakout last September and had to change my rear tire in May (3100 miles). I had ran the Psi recommended in the OM (42 Psi) which ran my centerline out to almost flat in that amount of miles [had plenty of side tread remaining]. On the 2nd tire, I have lowered my psi to 36 and this did well on the Memorial Day run to the Wall with and without a passenger. I have already logged ~2500 and it looks like, with reducing to 36 psi, I may make it beyond 3000 miles before I have to shell out another $374 for the third tire in less than a year. At $374 (installed), I am looking for a different tire instead of the HD Dunlop that will offer the same performance and stick, but get more miles; THOUGHTS???
Sara Daniels (10-11-2020)
Just checked your location - wow, PEI? I used to have a tshirt from Bro's in Windsor, NS. I guess heat isn't your tire problem, eh? (Sorry, too many jobs in NS.)
I was wondering how those 240 tires were going to hold up. If you get 6k or so with 36psi I would consider that on avg par for the 200mm tire on the fatboys. 42 psi seems high for a 240 tire with no extra weight. my FB manual says 38 cold for standard weight(ie, no passenger) 42 fully loaded.
The mileage is shitty on these 240 dunlops. Im on my third tire at 10,000 miles. Somehow I keep picking up nails or screws before they wear past 3/32 tread left. The tire and wheel warranty covers tire and install. The salesman warned me that they would wear quick and said use, I mean buy the tire and wheel warranty. I think ill try the commanders by Michelin at some point, and jp cycles is having a tire sale right now online. The 240's are going for 200-230 bucks and their are 5 different tires to pick from.
