High beams and passing lights
Maybe someone can turn up a diagram, or confirm what I'm thinking...
I looked into doing this on my Road King a while back, and never got around to it. If I remember correctly, it was just a simple deal of cutting the hot wire to the passing lights from the low beams and splicing it into a constant hot. You can leave the switch in line, so you can turn them off if you need/want to...
https://www.hdforums.com/forum/10891101-post96.html
The HD cable will get the job done, but for those that want to do the wiring modification themselves, here is a link to the wiring diagram:
Not true. The passing lamps are still controlled by the Passing lamp switch, so you control whether they are on of off with the switch.
Or, do a goggle search. Plenty of options.
https://www.google.com/?gws_rd=ssl#q...+light+adapter
Bones
Bones
