oil seal in 86 pump
oil seal in 86 pump
Hi Guys
86 883 sportster... I got the new seal for the oil pump plate but I'm not 100% percent certain which direction it installs into the plate and to me the manual is not quite clear. Can someone please tell me if the seal goes in as shown in the first photo or as shown in the second photo? Near as I can tell its the direction shown in the second photo but not absolute certain.
Thanks
Thanks
I think it goes like number one since the lip should face the highest pressure which I think is the large pump rotor is on the side. Then I pondered is that backwards. Is the big one the high volume, low pressure return and the small one the pressure side? Back to my manual? HA Sure it spells out which side the lip goes in the instructions. Well I reread and the small thinner rotor is the pressure side. We all know the lip faces the the side you want to seal. So are you trying to seal the side that feeds the engine or seal the return from sucking oil from the engine feed side. Put it like the old one was? HA . The call out in my EVO for the larger gear pumps states lip to drive side. My Sporty manual is in German and I am too rusty to see it but it's in the instructions on installing the center seal.
ok this may clear things up, I think I may have just been misreading the manual. It clearly states or it appears to clearly state to install the oil seal so lip is toward gerator set, feed (thin) (12)
This is the way I installed the seal which I'm almost pretty sure is what the manual is saying.
- seal installed with lip facing (12) gerator set feed , both views
- the seal and plate in place on the shaft and lined up with pin
- and (12) gerator set feed in place over (14) outer plate with seal
I'm hoping this is correct. It does appear quite stiff to turn when the (6) cover is held down tight.
VDeuce
Milwaukee Eight (M8)
11-22-2018 10:16 PM
