Wheels
12-14-2014, 01:52 PM
Wheels
Anybody know if 03' wheels will fit an 06'? I picked up a pair for $100.00 and was going to get them powder coated and put them on my 06'. Thanks for any info.
12-14-2014, 03:20 PM
Should do. You can check things like this by using one of the on-line parts websites, like
this one. Cast wheels for both years have the same part number.
12-16-2014, 05:18 AM
Thanks. I was told that they would fit if I installed the bearings,races, and spacers for an 06 but wanted to make sure before dumping cash into them. Thanks for the link. it will come in real handy.
12-16-2014, 03:36 PM
Damn, you scored. I'm on the hunt now for a set and am coming up dry. And you are right, change the internals and the wheels will work fine.
12-16-2014, 04:19 PM
Quote:
Originally Posted by
shiftace
I have some 2002 13 spokes for sale
12-16-2014, 04:24 PM
You need to change the rear wheel bearings to 3/4" as rear on an 06 came with 1" bearings. The fronts are both 3/4 so that should fit fine.
12-16-2014, 04:57 PM
Hogpro
Good point, Hogpro
This also means you'll likely have to bore out the hub to fit a 1" I.D. inner spacer.
12-17-2014, 04:40 PM
Rayvan
Good point, Hogpro
And that was what I forgot to post.
tomlite
09-09-2012 10:33 PM
por2gezo
03-28-2012 08:51 PM
jamesrgarner
10-16-2009 12:18 PM
RLFINCH
04-03-2008 07:51 PM
lawsonsr
02-18-2007 02:52 AM
