Oil from Breather
Old 07-01-2015, 10:42 PM
chimchim1's Avatar
chimchim1
chimchim1 is offline
Stage I
Default Oil from Breather
Hello,
New to forum and hopefully this isn't covered somewhere deep within...if so, please direct if you've seen same issue.
I've got a 1982 Sportster XLH 1000 that has oil coming from K&N breather tube on right side of motor/crank cover- its mainly when I get on it higher speeds, freeway, etc...starts to blow out from filter.
Photo of problem area attached.
Hopefully not a "major" issue and someone here can help out.
Thanks in advance!
Old 07-01-2015, 10:46 PM
OddJack's Avatar
OddJack
OddJack is offline
Did you recently change oil? You probably have too much in there.
Old 07-02-2015, 10:21 AM
SLV's Avatar
SLV
SLV is offline
That is the typical cause for this. The next is blocked oil ports/paths inside the top end. It's likely just overfilled though.
On newer Sportsters, this can be caused by using the incorrect oil filter. Sportsters need a filter with no better than 30micron flow. When people attempt to use a 10micron filter, the oil pump can't force oil through the system fast enough. This causes oil pressure to build-up in the lower case and blow out anywhere it can go. I'm not sure if this is true for Iron Heads, but I assume so since the oiling system is similar.
Old 07-03-2015, 11:14 AM
misput's Avatar
misput
misput is offline
Originally Posted by chimchim1
Hello,
Thanks in advance!
Run a hose overboard and ride that sucker. It's the nature of the beast.
Old 07-04-2015, 05:55 AM
Wildon883R's Avatar
Wildon883R
Wildon883R is offline
Yes mine has spewed breather bolt oil in tiny amounts since i got it! Its not just bikes but about any motor does it. You just don't see it on cars and trucks.
Old 07-04-2015, 06:19 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Agree w/others...run 'er 1/2 qt under full and you'll hopefully have 0/less oil blow-by.
Old 07-04-2015, 05:02 PM
wanabe's Avatar
wanabe
wanabe is offline
since having that problem when I got the bike, I now keep the oil level below half way. Also installed a "horse-shoe" breather- no longer have this issue.
moto monkee
06-21-2020 07:45 PM
1flhtk4me
05-09-2017 07:12 PM
takamine4
Oil Archive (no new posts)
08-19-2012 12:46 PM
Griff012FLHX
10-23-2010 08:41 AM
molestrangler
08-20-2009 03:58 PM
Quick Reply: Oil from Breather
