Small fork extension this winter
I will. I'm going to keep the paughco z bars, sissy rail, some other bits.. and if I can't do a color change I have some 2011 dodge ram tequila sunrise left over from the first time I painted it. Yeah I had it first hahaha. Thinking of a dark red with a ton of gold flake, then using the gold for either scallops or a dual pinstripe on the tank and fender. Its raining or id get a pic with the le para and p pad. I love the late 60s style bikes.
Yamaharley ,they should be 24 3/8"
http://www.motorcyclemetal.com/gpage25.html
the damper tubes. Here's an old (but good) thread on the XLF
with alot of pictures starting at #25
http://xlforum.net/vbportal/forums/s....php?p=3232968
The pic that caught my eye was this one:
hth,
T.
scooter1128 (11-27-2016)
If you only want to go up maybe 1-1.5", you could just change
hth,
T.
hth,
T.
so little info out there specific to the Low
you more suspension travel. Probably makes for a better ride.
If you get time, check out the link above, it has some Low info in it.
good luck,
T.
A bit worried about the job, lots of little parts, looks kinda complex.
