Check engine light
Check engine light
2015 48.
I just added passenger pegs so I had to remove the exhaust and loosen lots of parts.
I also put a new battery in. Yuasa high performance AGM.
As soon as I start it the check engine light comes on.
Advice on what to check?
I'm new to HD. Do I bring it to HD to read the check engine code?
There is a way to check engine codes. A simple google search should help you there. It involves turning your ignition on and off a couple times and the code comes across the odometer . I don't remember the exact procedure. But will give you a code and the same search online should give you the answer you need
I had one get damaged by the dealership shop a while back, apparently they are pretty fragile and easy to damage if not being careful.They had to replace it. Not sure if the stock narrow band sensors are expensive or not but the wide band one they had to replace was 70 bucks and they do just screw on out. Just disconnect the sensor so the wires don't twist up on u. Hope u get it figured out soon.
The stock gaskets like to bunch up if you are not careful. Aftermarket are more compact. I'm staying OEM and will just be careful.
If they bunch up they can restrict flow and allow a leak. It sounded fine in the 2 miles I road it.
For now I'm figuring out the FuelPak and see what I can do with it.
I'm learning.
I'm learning.
