Hardtail battery
Hardtail battery
So,much to my dismay,I built this battery box...
for the full size battery that was in my Sporty when I got it.I now find that it does not fit in my hardtail frame(I built it before I bought the HT,as a practice welding project).It won't allow for the chain to clear,and sit anywhere cleanly in the lower rails.What are you guys using for a smaller/comparable battery.Or where/how can I fit this in on the frame as it is?
Received 3,963 Likes
I have one in the bike below for 4 or 5 years and it works as good today as the day I installed it. Gives me room for all the stuff I have under the seat.
It's also the battery I will be using on my chop I'm working on.
If you get a smaller battery, you will have to cut down the batt tray made, but then it will fit easily between your bottom rails.
You can see from pic below, I have a ton of stuff in there...no way would it all fit with a OEM size battery.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
I use an Antigravity Lithium. It is really small compared to stock. See this LINK for photo's and specs.
Thanks for the pics dude.That looks different than the AntiGravity battery.Which one did you use?You got any pics of those sweet looking pipes?
Yeah, I'm using the 12 cell. It is a high compression 1250cc engine, and the recommended size for that is the 16 cell. But I have had no issues using the 12 cell with it.
It's quite a bit smaller than the one pictured on 08fxd's ride above.
But it all tucks in nicely...I took this pic right after I finished installing the TT-
http://www.ledsledcustoms.com/category/battery-boxes
drspencer
04-18-2012 10:18 AM
albngore
01-15-2010 07:54 PM
