well getting ready to do the 5000 mile service and am getting everything prepared and i don't know which oil i should get to lubricate the throttle cable and the lever pin if it needs it and all the stuff thats gonna need lubricating.
Any light machine oilorATFis fine. I use Rem Oil. WD-40 is the worst for lubing cables. It more of a solvent than a lube. It will clean your cables really welltaking off the old lube. It will then evaporate and leave your cables dry.
I use Motorex Joker 440 spray on my cables...Use a cable oiler attachment... Joker 440 goes on wet, then turns into a teflon like coating, it is SLICK.. I sprayed my car door hinges with it and now my doors will not stay open.. You can get it from Custom Chrome.. Canyonrun.com is a dealer... around $8.00 a can
