Dynatek vs. Twin Tec ignitions????
Old 07-21-2008, 04:21 PM
FlyinJ's Avatar
FlyinJ
FlyinJ is offline
Default Dynatek vs. Twin Tec ignitions????
Thinking about switching out my non-adjustable SE &nbsp\\;ignition for either a Dynatec or Twin Tech, any opinions on which is better would be GREATLY appreciated.&nbsp\\; Price on each is about the same, just want the best unit.
My bike is an 06 883 Custom, punched to 1200 with SE intake and V&amp\\;H straight shot pipes.&nbsp\\; May upgrade cams
eventually, but happy with what I have for now.
Old 07-21-2008, 05:08 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Default RE: Dynatek vs. Twin Tec ignitions????
Dynatec &nbsp\\;
Old 07-21-2008, 05:23 PM
cHarley's Avatar
cHarley
cHarley is offline
Daytona Twin Tec
Old 07-22-2008, 11:48 AM
cdaxj's Avatar
cdaxj
cdaxj is offline
this may be a dumb question, but i'm learning.
what's the benefit of upgrading the ignition?
Chad
Tampa, FL
Old 07-22-2008, 12:15 PM
cHarley's Avatar
cHarley
cHarley is offline
ORIGINAL: cdaxj
Chad
Tampa, FL
This thread might help: https://www.hdforums.com/m_3369501/tm.htm
Old 07-22-2008, 04:20 PM
Zimbob's Avatar
Zimbob
Zimbob is offline
Dyna, hands down.
Old 07-22-2008, 06:18 PM
jag1886's Avatar
jag1886
jag1886 is offline
&nbsp\\;There is almost no advantage to upgrading the ignition unless you are spending a bunch of money on the engine and want to get everything out of it you can.&nbsp\\;
&nbsp\\;So if you're not doing engine work don't mess with the ignition.
Old 07-22-2008, 06:42 PM
cHarley's Avatar
cHarley
cHarley is offline
Sure there is, its called fixing the ignition timing that the EPA screwed up, just like they screwed up the air/fuel system. But I dont seem to agree with most of your opinions anyway.
Old 07-22-2008, 10:03 PM
ray1970's Avatar
ray1970
ray1970 is offline
I have been thinking about upgrading the ignition module on my wifes 06 883 to cure the dreaded "carb fart"....&nbsp\\;I hear rumors that it really isn't anything to do with the carb but is caused by too little (or too much?) timing advance at low rpms.
Old 07-23-2008, 06:07 AM
xFreebirdx's Avatar
xFreebirdx
If you have a carb. This makes a world of difference. http://cv-performance.com/index.php?...\\;productId=2
Quick Reply: Dynatek vs. Twin Tec ignitions????
