What is the difference between 883 and 1200?
Old 10-13-2008, 10:23 PM
Ozoneman's Avatar
Ozoneman
Ozoneman is offline
Default What is the difference between 883 and 1200?
Is there any difference other than the engine between the 883 and 1200 sportsters? Do they use the same frame?
Old 10-13-2008, 10:54 PM
chaos5's Avatar
chaos5
chaos5 is offline
Old 10-14-2008, 01:46 AM
jdvorchak's Avatar
jdvorchak
jdvorchak is offline
Some guys will of course say about 317 cc difference.. That is about it though. Same frame and lower end. I think the 1200 has a larger bore and stroke and a lot more torque and hp and an air cleaner that looks like a can of ham.
Old 10-14-2008, 05:51 AM
nevets61's Avatar
nevets61
nevets61 is offline
Other than the obvious mentioned 317cc, the other difference is in transmission gearing I believe. The frame of the two are the same. Drive pulley (gear) on the rear wheel is different by a couple of teeth too, I think.
Old 10-14-2008, 05:54 AM
goinsideways136's Avatar
goinsideways136
goinsideways136 is offline
about 15 to 20 hp. look almost identical. steeper gearing in 883.
Old 10-14-2008, 01:47 PM
Racer57's Avatar
Racer57
Racer57 is offline
I also am curious. Specifically as it relates to the clutch. I am seriously thinking of doing the 883 to 1200+ conversion on my 08 sportster but never have heard if one has to upgrade the clutch or not.
Old 10-14-2008, 08:46 PM
1200Cdriver's Avatar
1200Cdriver
1200Cdriver is offline
The stroke is the same, the 883 has a 3.00 inch bore and 3.81 stroke the 1200 has a 3.5 inch bore and a 3.81 stroke. The 883 comes with a 27 tooth countershaft sprocket/pulley and the 1200 comes with a 28 tooth in the US. European models come with 30 tooth countershaft pulleys.
Old 10-14-2008, 08:59 PM
VENNUM's Avatar
VENNUM
VENNUM is offline
How does the number of teeth in the countershaft pulley make a difference?
Would it benefit a U. S. bike to switch to the 30 tooth pulley?
Is it done regularly?
Is it simple to do?
Old 10-15-2008, 08:15 AM
1200Cdriver
The Euro bikes engines turn at a lower rpm for a given road speed than ours do, the 27 tooth on the 883 enhances its acceleration but increases its engine rpm for a given road speed. Using the 27 tooth on a 1200 would increase its acceleration ability but reduce fuel economy. Any change to the CS pulley requires a speedo recalibration.
Unless you're a drag racer and timing your acceleration runs, pulley changing is not going to do much for the seat of the pants feel.
Old 10-15-2008, 01:34 PM
kk6pg's Avatar
kk6pg
kk6pg is offline
I thought it was a can of ham. Now I'm bummed. Lunch was sounding pretty good till I read this
Quick Reply: What is the difference between 883 and 1200?
