How difficult is it to remove the plastic wiring harness underneath the tank on a Nightster? I have seen alot of bikes like this, and want to do the same to mine. Thanks...
Not very difficult. You would just have to take apart the connectors and reconnect the pins without them. I assume you would just use heat shrink tubing to protect the pins. I haven't done it, but I do a lot of wiring and that's how I would do it.
I have mine removed, was pretty easy, I even kept the deutch connectors in tact. All I did was space the tank up about an inch or so, then zipped tied everything, real tight, between the tank and frame. It's makes it look at a lot cleaner.
I didn't remove my tank, just unbolted the front and propped it up. It may have been easier to remove the tank, but didn't want to mess with disconnecting the fuel line. If you look at this thread... https://www.hdforums.com/forum/sport...nightster.html
