Headlight adjustment
I go out in the street at night and adjust the light so I am comfortable with the distance of the beam. I ride alot of freeway to and from work doing 70+ most of the time so I have mine raised up a little higher so I can see farther ahead.... There is a Proper way to adjust it in the manual, but I think it puts the hot-spot too close to the front wheel.
35" to the top of the beam sounds about right, but the factory adjustment for my bike was TERRIBLE. Way too high. 5 to 10 feet in front of the bike, I was getting better illumination from the yellow turn signal/running lights than I was from the headlight.
What Iv'e alway s done, for bikes and cages, is to find a level parking lot, and park behind a car at about the same distance you would follow. Balance the bike upright with most of your weight on the seat, then adjust the headlight down so the top edge of the low beam is about tail-light high on the car in front. At least then, you aren't blinding anybody. Remember, the front end will come up under acceleration too, so the worst case is you blind oncoming traffic and they retaliate with their high beams, so neither of you can see.
Then see how it does illuminating the road in front of you. You will probably want to adjust it down even more. Low beam should intersect the road directly ahead of you. High beams shoud have the top of the beam parallel to the road, and the lower part of the high beam should still light the raod about 25 feet ahead of you.
Same here. I rode for a week before I saw where the beam pointed - on the ground about six feet in front of me.
Most state standards call for 4" drop at 25 feet on the low beam setting.
If the headlamp center is 35" , then the hot spot would be aimed at 31" height on the wall.
E-Beams are similar , but easier because of the beam cutoff is so sharp.
If done properly , the high beam is automatically correct.
Mick
Mick
