coil/ignition relocation question
We are glad we could help out
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
I ended up buying some rubber washers and installing them on the bracket bolts. It vibrates less now. I also used some WD-40 on the key and inserted and removed the key from the ignition cylinder multiple times. Everything seems to work a lot better. That's the last time i buy a kit off of Ebay.
But on that, I seen people get the low profile aftermarket ones and mount them on the front of the frame , between the forks and engine. If you have engine guards, I dont know if that causes issues with that spot.
