Parts list for full 48 front end conversion on sporties
Old 04-06-2010, 11:07 AM
rkaiser's Avatar
rkaiser
rkaiser is offline
Default Parts list for full 48 front end conversion on sporties
Anyone have the parts list for the front end conversion?
Forks, wheel, tire, handlebars, mirrors, mounts, etc?
Old 04-06-2010, 11:11 AM
fox4's Avatar
fox4
fox4 is offline
Your local dealer would be the best too answer that question. They have the stock parts manuals for all of the bikes. They will be able to open that thing up and order everything you need down to every last bolt.
Old 04-06-2010, 01:44 PM
whatwhat's Avatar
whatwhat
whatwhat is offline
I'm just going to use a Mid Glide triple tree set to use with my 39mm iron fork tubes. Then get yourself a 16in rim and fat tire, you'll be good to go. But don't forget to get the axle conversion with the triple tree set. Most HD 16in rims won't fit with the stock sportster axle. Here are a few pics of it being done on a nightster and some other XL:
One of those is a fat boy low wheel I think....They are both using Wide Glide triple trees which are too big in my opinion. That's why I want to go Mid Glide like this nightster:
But with the fat wheel of course.
Hope his helps....
Old 04-06-2010, 07:45 PM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
I just asked the same question today. Needed info on the 48 wheel/hub myself but Bruce Rosmeyers Sunrise had no info what so ever. Not in the 2010 PartSmart
Old 04-06-2010, 07:50 PM
snacks63's Avatar
snacks63
snacks63 is offline
parts list,,, 1- sell your bike
2-buy a 48
Old 07-13-2012, 03:47 AM
UrbanGuerilla's Avatar
UrbanGuerilla
UrbanGuerilla is offline
6th Gear
hi guys,
I know I'm late on this one, but I'm trying to look into the possibility of doing the same thing on an 883. Change the stock triple trees to wider ones - like the last pic that whatwhat posted. Its an iron with a stock rear wheel mounted on the front end. Same stock forks, but different triple trees.
Trying to work out what would fit a wider tyre.
Anyone have any ideas what the trees are on the bike in the last pic?
Old 07-13-2012, 07:08 AM
FlatIron's Avatar
FlatIron
FlatIron is offline
Originally Posted by UrbanGuerilla
hi guys,
It's a Vulcan kit... I have their wide glide kit... I must warn you the owner is a piece of SHITaki and if you have any former issues (which are very possible) you will have a very hard time communicating. You may even get cursed off and threatened like he did to me... Good luck
FlatIron's Avatar
FlatIron
FlatIron is offline
hi guys,
It's a Vulcan kit... I have their wide glide kit... I must warn you the owner is a piece of SHITaki and if you have any fitment issues (which are very possible) you will have a very hard time communicating. You may even get cursed off and threatened like he did to me... Good luck
Old 07-16-2012, 05:29 AM
UrbanGuerilla
6th Gear
Thanks FlatIron,
I hope not anyways. Did you get a salty response after buying their product?
I've seen the vulcan kits, but all seem to have the same 3 lines of exposed aluminium on them. This bike in the pic has some really clean triple trees. I think maybe they've used a mid glide front end.. not sure. New to all this. Just doing some detective work.
Thanks
Old 07-29-2012, 01:12 PM
Joedude's Avatar
Joedude
Joedude is offline
Hey all
I had the same problem with Vulcan
Quick Reply: Parts list for full 48 front end conversion on sporties
