Screaming Eagle Ignition Module/Coil/Wires
Old 10-19-2010, 05:46 PM
TangoDown's Avatar
TangoDown
TangoDown is offline
Default Screaming Eagle Ignition Module/Coil/Wires
Looking to complete the Stage 1 process as described by Biketech.
Bike is a 2005 Sporty 1200 Custom.
My bike already has the SEII pipes, carb jetting, and SE air intake. I believe it is still running the stock wires, modules, and coils.
I have tried looking on the Screaming Eagle website, but maybe I am not looking close enough. I know this may be a dumb question, but do they still make the SE ignition modules and where can I get them? Should I support my local stealership (they've done right by me before) or should I save some $$$ and try to pick up the parts online? Any recommendations as to where to go?
Looking for the following parts (I believe). Correct me if I'm wrong:
1) Screamin' Eagle Street Legal Performance Ignition Module
Harley-Davidson Part Number 32630-96
2) Screamin' Eagle Performance Coil
Harley-Davidson Part Number 31653-97
3)
Magnecor 8.5 mm Harley-Davidson Plug wire set
Anything else I am missing? Thanks in advance!
TD
Old 10-19-2010, 06:39 PM
Terp84Alum's Avatar
Terp84Alum
Terp84Alum is offline
My SE catalog shows 31759-04A:
SCREAMIN’ EAGLE PRO PERFORMANCE IGNITION SYSTEM – XL MODELS®
This module is programmed to allow the engine to turn 7000 RPM and retards timing by 5 degrees at wide-open throttle.
31758-04A Fits ’04-’06 XL883 models. $119.95
31759-04A Fits ’04-’05 XL1200 models. $119.95
32471-06 Fits ’06 XL1200 models. $119.95
Old 10-19-2010, 06:40 PM
Terp84Alum's Avatar
Terp84Alum
It sure isn't the PN you have:
32630-96 Fits carbureted ’96-’99 Evolution 1340-equipped models. $124.95
Old 10-19-2010, 06:41 PM
Terp84Alum's Avatar
Terp84Alum
SCREAMIN’ EAGLE PERFORMANCE COILS
These coils provide over 40,000 volts to powerfully spark your motor. Quick rise time for high RPM and high compression performance applications.
Fits ’84-’99 carbureted Evolution-equipped and ’86-’03 XL models with electronic ignitions (except ’98-later XL1200S.)
31653-97 Black. $54.95
31654-97 Red. $54.95
31620-88A Orange. $49.95
Old 10-19-2010, 06:43 PM
Terp84Alum's Avatar
Terp84Alum
H. SCREAMIN’ EAGLE PERFORMANCE SPARK PLUG WIRES FOR SPORTSTER MODELS
These custom 8mm terminated plug wire sets are larger in diameter than stock wires and feature silicone plug boots and suppression core so that your electronic ignition is not affected. Use with your stock production coil or the perfect addition when upgrading to one of our Performance Coils. Available in black with orange “Screamin’ Eagle” script or orange with black script.
Fits ’04-later XL models.
31956-04 Orange. $12.95
31958-04 Black. $12.95
Terp84Alum's Avatar
Terp84Alum
BTW, I put the SE stuff on my 02 and am very happy with it.
Old 10-19-2010, 08:37 PM
TangoDown's Avatar
TangoDown
Terp, you rock. Thank you for looking up those P/Ns for me.
Do you think I should order through my local HD guys/gals or is there an online storefront you could recommend?
TD
Old 10-19-2010, 08:58 PM
TangoDown's Avatar
TangoDown
I am unable to find this on the HD website, or the SE catalog. Just looks like all ignition modules are not included in catalog. Hmmmm!
Old 10-20-2010, 06:39 AM
Terp84Alum's Avatar
Terp84Alum
I would call your local HD dealer. My SE manual is the 2008 so maybe they superseded it. The HD dealer can tell you. Once you get the parts, look at Chicago Harley and Zanotti's to buy online.
Old 10-20-2010, 06:59 AM
woodworking1's Avatar
woodworking1
woodworking1 is offline
I was told by my local HD dealer that the SE ignition modules have been discontinued. They had problem of shutting off at highway speeds. They were recalled and never updated. I have been looking for one as well.
John
I googled it and found some interesting info
Quick Reply: Screaming Eagle Ignition Module/Coil/Wires
